ls 400 brakes upgrade...do i need a bracket?
if i upgrade to Ls400 calipers and rotors do i need a special bracket? and if so what kind and where can i get it?
They bolt up without any bracket but don't clear the tie rod bolt. You need either RCA's like was said or to shave the caliper and unused threads on the bolt to make them fit. I shaved the bolt and caliper and it's worked out fine for me, the RCA's would be a better option if you're on coilovers and can adjust the ride height to compensate for the RCA's.
rcas dont shave the bolt to the tie rod because when you go to get the alignment they will ruin them pop the off wont be able to thread the nut back on. and you really dont want to shave the caliper and go to far and have it fail under pressure while your braking... i made some rcas with washers and 1/4 inch plate and my weilder. but i am waiting for figs histeer arms with better lower ball joints and the rca clearance built in check them out..
