Brake Master Cylinder
Old 02-12-10, 02:35 PM
imerali
imerali's Avatar
Default Brake Master Cylinder
I live in Toronto and for the past 3 years when its cold outside I hear a squeaking noise that comes from my brake master cylinder after I let go of the brake pedal. It only happens in winter when its cold out but each year the problem gets a little worse so I recently took it into Lexus to get checked out. They said my master cylinder is failing and I should get it replaced. It's $1,800 at Lexus and I can't seem to find a refurbished one around here.
Any suggestions?
Old 02-12-10, 02:50 PM
sivikvtec
sivikvtec's Avatar
a great resource is www.car-part.com, its a database for junkyard parts. There are quite a few on there for under $500.
Old 02-12-10, 02:54 PM
rgarjr
rgarjr's Avatar
Yeah man, I have the same problem with mine, except it makes the screaking sound every single time I press the brakes, no matter what temperature it is outside. The sound last about 3 or 4 seconds and it sounds like the ABS motor. You can feel the vibration on the brake pedal as it happens.
Very annoying as you can imagine.
Old 02-12-10, 05:43 PM
rgarjr
rgarjr's Avatar
Just swapped out mine with a used one today. Nice to drive without the thing screaming everytime you press the brakes. Shop labor was 100 bucks to do the swap and bleed.
Ken167
09-01-18 02:39 PM
SorrGwa
Suspension and Brakes
39
05-08-17 04:00 AM
picodroid
03-29-14 07:08 PM
gcam77
02-06-08 08:53 PM
Lexs400
10-09-03 10:14 AM
Quick Reply: Brake Master Cylinder
