Alignment/camber/tire wear blah blah blah....
So, I'm low . My exact drop I'm not sure. I just took it down as low as I can go without rubbing.
Then I experienced tire wear and found out about our cars lack of camber adjustment.
Some time passes and I see rear camber kits. I believe I even saw a company that makes a front camber kit as well.
I'm going through a new front tire every 10k or so. Everytime..excessive inner wear. Camber.. yes?
A local shop who does good alignment said that a camber kit is useless because I'm so lose to rubbing fender as it is. Adjusting my camber would be useless.
Perhaps I should just accept that if I want to look good and ride low that i gotta drop lots of money on tires very very often? I cant help but think there's SOME way to go low and sit well enough to get some life out of my tires.
Any input/experience from anyone beyond "you need camber adjustment"
any pics of how your car sits? i just installed megan coilovers and i got a lot of negative camber im gonna get a alignment today, hopefully thye can fix it a lil bit. i dropped 2" in the rear and 1.8 in the front i think
Without knowing much about this; From what I've been told by a few different shops it's either raise it up, go smaller wheels (um, no), or go through tires.
I'm hoping someone will say differently and offer some advice on how to do so.
Hoping some experienced person will chime in.
My Toe, despite lots of hard bumps..has not gone far out in almost a year. My specs were:
Left front Right front
-2.2 camber -2.1 camber
7.5 caster 7.8 caster
-0.02 toe -0.08 toe
Total toe -0.11
Steer ahead 0.03
Left rear Right rear
-2.3 camber -2.6 camber
-.03 toe 0.11 toe
Total toe 0.08
Thrust angle -0.07
Here is a scan from when I had my IS350 so you can see what the spec allowance is. Your ride height looks pretty close to what mine was but you may be lower in the front. I was just with in spec on my TOE and had no issues with my PS2 tires and driving the heck out of the car all the time.
There is also a thread I had started and a few others had posted what there info so you may want to search and check to see if there is anything helpful in that thread. Lobux would be a good person to help you out.
dave197878
04-03-09 07:15 PM
