Stainless Steel Brake Lines
Long story made short: I received a gift of some stainless steel braided brake lines for my IS last Christmas. The lines ended up being completely the wrong length so they were never installed.
Now I'm interested in getting this done again and I'm having some difficulty finding any vendors who support our vehicle.
If there's not a place where I can purchase a set of the correct length my other option is to get them made by a local shop. In order for this to happen I need to know what the actual correct length is.
So the question is, could any of you tell me:
- A vendor who sells lines for our car of the correct length
or
- What the correct length of the lines would be
Thanks
or
Thanks
I recently ordered these and put them on. They seem to fit very well and appear to be the same length as stock. Shipping was expensive tho (I did 2 day shipping about $30). It came very fast tho and was in stock.
http://www.propartsusa.com/index.php?cPath=633_658_1258
I also bought some new pads, EBC Green stuff, and I pasted the link, but it appears I'm not allowed to post links to their site here? It was from Auto Parts Warehouse. Very fast and cheap over night shipping (about $3.50).
Thanks in advance
Tech Info Resource
Braided lines on Air Force airplanes are inspected every 90 days (phase inspection). If you have more than x number of broken strands (based on size) in a 1" section, you replace the hose. Braided lines on automotive brakes should be inspected for damage AT LEAST annually.
The install was relatively easy, although we had problems with other stuff.
You may have seen my other post regarding the stuck slide pin on the rear right caliper. That has led to a lot of issues, and I still haven't quite sorted them out yet. I did manage to get my rear slide pin unstuck a few nights ago. If I have time tmmw, I may be able to finish it all. I should be putting up a new post with pics of everything and my whole experience through it all soon.
So in the short time I did get to drive around, I wasn't able to tell any difference yet due to the new pads and rotors not being worn in. I guess I should have put them on individually, but I figured I already had the wheel off, haha.
Last time I had them bled, they felt great for the next 6 months or so.
Tech Info Resource
I hand-built braided stainless brake lines for my 1980 Honda 750F in 1981. I used -4 line from the master cylinder to the Tee, and -3 lines from the Tee to the calipers. After reading all the great things the magazines had to say about braided lines, I was absolutely certain all the hard work of cutting the tubing, fitting the ferrules, and assembling the whole thing one line at a time was going to be rewarded with the most fantastic braking I could imagine. Really.
Imagine my dismay when after spending two full days getting this all done piece by piece by hand, (myself) when I couldn't feel any difference at all from normal street braking to full threshold braking.
Ever since then I've been a lot more focused on bleeding the brakes well. It truly does make a big difference. The rest of the stuff is minor differences. Braided lines are cool, they look great, and you find them on real race cars, but in the end they're really nothing special from a pure performance perspective.
Only in your mind. Most of the OEMs use kevlar braid on brake lines these days. It's stronger, lighter, and because it's covered, it's more abrasion resistant than braided stainless over teflon. It can also go 10 years in service without requiring regular inspections because you don't have the flex and braid breakage problem braided stainless lines can have.
kit cat
27
11-09-10 04:37 PM
Overclocker
Suspension and Brakes
09-13-05 06:02 PM
