On crank up Gas smoke fills the air !!!
OOPS WRONG PART OF THE FORUM... I WILL MOVE IT !!!
How can I fix this issue it seems to dump heavy fuel to the point that the smoke is blinding...Now once it warms up the smoking stops, but there is still a smell of gas present at idle.
I have changed:
-The coolant temp sensor (the OD light has now stopped blinking)
-I have a code 27 (secondary oxygen sensor) I dont know which to change (im on a budget).
-The computer...Im not sure if this is a part or the actual problem. I bought one from ebay. When I use either the original one, or the ebay one I get the same result.
any advice would be appreciated !!!
As always
THANX IN ADVANCE
Wayne
I have changed:
As always
THANX IN ADVANCE
Wayne
