Help. Are these the right caster bushings??
i bought these caster bushings on ebay so im not sure which daizen kit number these are from. i have the manual and it states both kit numbers: G2-2002 and also G2-2002A. i want to make sure i have the correct ones for my 98 GS400. i found a number on the bushings which reads CA-116. heres some pics and maybe someone can confirm if these will fit.
.....the daizen kit you need is the g2-2002,the g2-2002a is for the 2001+ model as we have a different castor bushing.
IF you bought the g2-2002a i will buy it from you....i need one for my 2001
Scott1258
Suspension and Brakes
02-22-06 04:32 PM
