Ls400 brake and rim fitment question ???
So tonight I plan on doing ls400 bb upgrade, but my front rim is 20x9+30 just need to know if it will fit. Will I need 10 mm spacers or anything if so please let me know. Thanks guys!!
Its not so much offset as it is disk size. Traffic Star (Maya) has a Std/Med/Hi disks available. According to Traffic Star the RTS (aka Maya RT5) you will need the "Hi" Disk to clear the front calipers.
http://www.river-side.co.jp/matching/matching.pdf
if you are wondering "How do I know if I have Standard, Medium or Hi disk?" It should say on the sticker on the inside of your wheel. But according to the size chart from Traffic Star the 20x9 +30 is a Hi disk so you should be in the clear![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
http://www.river-side.co.jp/offset/rts.pdf
Just for a future note, never run spacers unless you absolutely need to. Anything larger than 5mm requires to have extended studs or else you wont have enough turns on the lug nuts and run the risk of your wheels falling off.
![](http://blog.mattalgren.com/wp-content/uploads/2009/07/knowing-is-half-the-battle.jpg)
I already got the brake on and it clears!! Works like a dream and thanks for the info. And i previously had the 10 mm spacers with extended lugs but removed the spacers for the time being. But they fit without the spacers!
Blavatsky
Wheels, Tires & Brakes Forum
04-01-07 02:51 PM
