Is Is350 rear caliper the same as Is250 rear caliper?
I have searching through the forums but the results are usually focus on the front. My question is that if the is350 rear caliper the same as is250? Also the rear rotors? Help me out guys!!
The IS250 Rear Disc is non vented and is smaller
THE IS350 is vented and bigger - identical to the IS250C and GS300 (at least for the cars in Singapore)
the caliper and rotors are differnt on all 4 on the is250 and is350s. because the master brake cylinder are different between the two cars. so brake bias will be different.
