Removing Pistons from IS350 Calipers
Turkey Killer
I bought a set of calipers that were painted really poorly and so I need to have the pistons pulled so I can strip the paint and clean the parts. I'll take them to someone and have them pop them out...hopefully they'll do it.
Turkey Killer
No...basically just remove the rubber seals with a flat head and then you can decompress the pistons by hand with some serious strength by placing a flat head (with rubber on the end so you dont scratch the piston) in the little lip that it has and push outward. You'll have to wiggle it and as I said use mega strength but they will come loose. I have yet to rebuild them cause my seals arrive tomorrow from sewell but I'm sure it won't be too hard.
