Help! SPC Control Arms installed now 1" higher WTF?
Northern California Regional Officer
I talked to SPC today. They said about a 1/2 inch of lift is normal. I think this combined with the change in camber may be the reason behind this. Thay are going to do some reasearch and call me back later today as to why it is almost 1" on my application.
I am now in the market for front RCA's and a rear camber kit while I am at it. This thing is going to end up costing me a fortune.
Uhhhh I don't understand. Do you intend on using the front RCA's to drop the ride height?
According to the photos you have adjustable coilovers.
As you add positive camber you will push out the top of the rim and get closer to the fender lip and lose clearance.
All offset recommendations need to factor the camber angle into the equation.
Yes moving the adjustmen to add more camber will move the arm away from the bags, but it's uncertain that it'll clear. And who knows, but the time it does clear, you'll have less camber than you originally want.
I would certainly not use these SPC as a solution to the rubbing issue.
The RCA's will serve 2 purposes, 1 make up the height change from the control arms and , 2 provide enough adjustability to set the front where I want it and be able to level both sides.
Hey Everyone,
Travis from SPC here. So i've read though this a couple times and have since talked with our engineers about the issue.
First off, not sure who you spoke to here, but our control arms will NOT raise your ride height in any way. The only difference as some have pointed out is the actual ball joint height. To get the adjustability, the assembly must have a place to go, therefore the ball joint assembly is about 1/2 in taller than stock.
What is really jumping out to me is the pre-load issue. We cant stress how important this is. The only reason for a change in ride height would be that the suspension wasn't loaded. I know you said you reinstalled them, my question is how? Was it a floor jack and 2 jack stands? What surface where you on? Though this installation is simple, we do recommended taking it to a professional, with most alignment racks there is a "jack and hold" function that allows the tech to evenly load the suspension.
I know you have another thread but about the clearance issue - I see you have coil overs, is the stock bump stop in them? If so you might need a longer bump stop. With the lowered suspension and the taller assembly, as you go low those components need to go somewhere, with out proper bump stops something will stop that up travel, in your case that might be the UCA and the fender.
Let me know, and please feel free to contact me. - tcozzie (at ) specprod.com
