List of wheels that fit TT and LS400 BBK
Old 06-27-13, 06:33 AM
  #61
INTIMAZY
INTIMAZY's Avatar
Just as an FYI, if anybody is looking for a spare that fits, 350Z spare tires are fine. They clear Supra TT front calipers AND they tuck inside our trunk also.
Old 07-01-13, 05:20 AM
  #62
SupraSam
SupraSam's Avatar
Update on the mkiv supra na wheels. They fit bit require a spacer (at least 5mm+)
Old 07-18-13, 08:48 PM
  #63
Vrank
Vrank's Avatar
^ that's funny mk4 16s don't because supra mk3 wheels fit perfect. ugly as hell on an sc but do fit.
And of course the 17"350z wheel too
File Type: jpg
Old 07-23-13, 06:09 PM
  #64
Cebo
Cebo's Avatar
So I've been doing an insane amount of searching and can't figure or find this out. I have the Supra TT wheels but they are the 16 inch ones. I am trying to see if they would clear either of the BBK upgrades.
Old 07-24-13, 02:46 PM
  #65
SupraSam
SupraSam's Avatar
Sounds like you have done zero research and can't read for **** either. TT wheels are off of the twin turbo supra. You have the non turbo wheels. Also, See my post like 4 posts above this one.
Old 07-24-13, 10:16 PM
  #66
Cebo
Cebo's Avatar
1. I did do crazy research and you are the first one to even specify a difference that I have seen at least between the wheels. All I have ever seen is Supra TT for my type of wheels. Nothing I saw differentiated between 16" vs anything bigger. So I had no way of knowing.
2. You didn't specify which ones it clears since the Supra TT calipers are a bit bigger. So I hope I (and others reading this that want to know for future reference) can assume both.
3. Yeah, my bad. I happened to skip over your second post since I didn't see it. Holy crap!! A mistake, god forbid.
4. No need to be an *** dude...forums are to help each other gain knowledge and be pointed in the correct direction.
Old 07-30-13, 06:15 AM
  #67
mnewxcv
mnewxcv's Avatar
anyone know if these 17" g35 wheels fit?
I know most g35 wheels seem to get the OK but anyone try these?
Old 10-01-13, 05:54 PM
  #68
SCFlash
Registered User
SCFlash's Avatar
Will the Varrstoen ES 1 18x9.5 with a +22 offset fit? i know someone mentioned above that the 19 x 9.5 were good to go
Old 10-06-13, 10:24 AM
  #69
ScBouncE
ScBouncE's Avatar
^^ Same question here. Will the +30 offset fit the ls400? I know the +30 doesn't work with supra tt brakes tho.
Old 10-06-13, 06:41 PM
  #70
xECKSx58
xECKSx58's Avatar
So stock SC300/400 wheels will fit over the LS400 brakes with 15mm spacers?
Old 10-06-13, 07:52 PM
  #71
moretoys
moretoys's Avatar
Yes, I have read this in several threads including at least once early in this thread.
Old 10-19-13, 07:40 PM
  #72
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
G35's will clear with ease.
Old 10-21-13, 02:23 AM
  #73
Cleanshots
Cleanshots's Avatar
you guys do realize offset means nothing in terms of brake clearance right? its simply the spoke design.. soo you need to find your min caliper clearance.. like so..
then you need to make sure that your wheel meets the requirement..
when you do measure for the min caliper clearance you need to measure to the highest part of the caliper.. and i do believe that the supra tt calipers are more bulky than the ls400 calipers.. the extra weight needs to show its-self in terms of size.. the supra calipers are significantly heaver..
here is some more stuff to help you..
Old 08-31-14, 08:50 PM
  #74
93aristogs
93aristogs's Avatar
Anyone know if the GS430 chrome/2nd gen Aristo Chrome tt 17 inch wheels fit over supra tt brakes and or ls400 brakes. Dont flame me but i didnt see this wheels covered or confirmed.
Attached Thumbnails List of wheels that fit TT and LS400 BBK-0efd405228b50b0e64f255fa108023cd_zps81380dff.jpg
Old 08-31-14, 09:23 PM
  #75
oldManTan
oldManTan's Avatar
17x9 cobra R reps +20 offset clear TT front and back
Quick Reply: List of wheels that fit TT and LS400 BBK
