Steering rack good/bad?Not solid at 60+
So the front driver side doesn't feel solid(out of balance)on the HWY at 60+ etc.so I did 9-3o'clock shake and it has noticeable movement.Even with the wheel off holding the caliper and steering rod it still has movement.I can feel the steering rod in the boot go in/out when I put my hand over it.Can I replace that part or do I need a whole new steering rack?I replaced all my front bushings including R/P a balanced/alignment a few months ago.Car is a 93 Manual,110,xxx miles,lowered on Megans,18x8.5.Rims....any ideas?Thanks
1 Post
Perhaps something as simple as your wheel bearing? Hub bearing? If you replaced the bushings, and it isn't one of the previous two things I mentioned, then it's probably a serious problem you should get professionally checked out IMHO.
Na,it's not the wheel bearing.It would have movement at 12-6 oclock for a bad bearing.this is at 3-9.I think it's the inner tie rod cause that's where I feel the movement is inside the boot where the jointvis.I just need to know if it's as easy as replacing the inner tie rod,maybe it needs to be tightened,or do I need to replace the whole steering rack?
1 Post
ahhhh, mkay. Well, it is a '93 so replacing the tie rod is likely, I agree with your diagnosis BTW. You didn't mention any knocking so no a joint me don't thinks...hmm. Whole steering rack?:..Doubtful, that only usually has to happen when there's a wreck involved.
Anyone chime in on here if I'm not covering this issue correctly, which I think I am.
Alright ,so it wasn't the steering rack ...the inner tie rod was done AND it was bent!!!....just glad it's driving without any out of balance feel...problem fixed!!now the rear....
400fanboy
13
05-24-19 07:14 PM
BoostAddct
Suspension and Brakes
17
10-28-11 09:29 PM
MIGS
Performance & Maintenance
12
11-14-10 06:25 PM
