New SPC/Eibach 2IS Front Camber Kit???
FYI: this was briefly discussed before:
https://www.clublexus.com/forums/sus...it-for-us.html
Also, carchitect had some interesting info in this thread:
https://www.clublexus.com/forums/sus...amber-kit.html
And, on my.is, one of their vendors (who IIRC is a vendor on CL as well) was looking for a test car:
http://my.is/forums/f157/we-need-you...sports-400528/
Tech Info Resource
Tech Info Resource
Tech Info Resource
If you don't fix the toe, there's no amount of camber you can subtract to fix edge wear. Usually if you get the toe right, the uneven wear stops. If you're at -2.0 or more, taking some out will be fine for a street driven vehicle. I generally prefer -1.5 for my cars and have no issues with wear unless the toe is wrong.
Hey guys, I should have a bump steer kit pretty soon that may work for the gen2's as well. An adjustable tie rod end that will allow spacing to reduce bump steer. Bump steer can cause inner tire wear from steering under compression when you are lowered. This will allow you to dial in the correct steering tie rod angle for what ever you are lowered to. I will post up more details when things are a little closer.
This is what the taperstud space will look like. A few more peices to get together.
![](http://i88.photobucket.com/albums/k195/Figbline720/steering/DSC07749.jpg)
Fig
Fig
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
![](https://www.clublexus.com/forums/signaturepics/sigpic106840_3.gif)
07IS350
Suspension and Brakes
03-30-11 04:59 PM
