What springs to get??
first of all, you should've looked through the suspension section. a search using the keywords "springs" and "coilovers" will pull up a lot of springs vs. coilovers debate. there's even a thread that's still on the front page of the 2is suspension section about coilovers and DD'ing:
https://www.clublexus.com/forums/sus...-for-a-dd.html
again, i'm not trying to be rude, but seeing as to how many times this subject has been covered, it shouldn't require a new thread. but as usual, it is what it is. anyways...
first of all, determine what you can AFFORD. if you do not have the budget for coilovers or you do not want to spend that much for coilovers, end of discussion. this is something YOU need to decide from outset before anything else.
next, determine what you NEED. what product specs are you looking for? what do you want to get out of it? what can you live with on a daily basis?
if you get past the above two, then figure out what you WANT. once you figure out your true budget and your needs, you should have limited your options/selections down to a handful. if not, then go back and re-evaluate everything again.
you'll get a lot of advice from here, but ultimately YOU need to decide. do your research here, but take some of the advice that you've gotten here so far with a grain of salt - mine included.
thanks for reading, and good luck with your decision.
from one of your post "reading is fundamental"
my suggestion would be eibach is250 springs. it'll give you about 1 inch in the rear and 1.5 in the front. with 19's, i had about 1 finger gap all around. the ride was very close to stock.
no need to bash this guy. if you read his post, he already listed his budget ~$200. he listed how much of a drop he would like. all this person is asking is which set of springs. this thread has nothing to do with springs vs. coilovers.
the discussion veered off from the thread title to what was discussed by several members - coilovers vs. springs. as such, i responded in response to the current topic in this thread.
reading is fundamental, but so is understanding the context of discussion before hitting the button. /OT
In terms of quality/handling this should be the order priced around your budget:
1. H&R (would of so gotten this spring if they made a higher drop. IMO best quality and handling but sacrifice comfort)
2. Eibach
3. F-Sport
4. Tein (have personal experience and heard many stories that since they are kinda soft, it tends to have a noticable sag after a year to a year 1/2 later. Would not recommend unless comfort is your main concern.)
2. Eibach
3. F-Sport
^ oh, really?
odd, i never had any issues when my 2is was on s-techs, and i had them for over two years/25k+ miles.
and compared to the oem sports suspension springs, they were definitely more firm.
maybe the caveat of "YMMV" applies?
I never said the Tein's gave me any issues. I had them on my previous car which was the latest prelude and I felt they were a little soft so handling wasn't significantly improved however, it was indeed pretty comfortable compare to the Neuspeed that I had on the Civic before the prelude and now the F-sport on the IS. Since I had a full body kit at that time on the prelude, I was able to notice every single drop or sag since it was lowered on 1.5 and 18" (so it was only a few inches off the ground). As time past, I was able to notice it became lower and YMMV does not apply because since my previous car was soo low on bodykit, I hardly drove the darn thing. I thought it was just me but after reading other people's reviews (there are people on CL who experience this along with their friends too), it reconfirms it. You just may not notice it or notice yet.
Don't get me wrong, it's still a good spring but I'm more into handling and performance w/ med range comfort since I drive hard vs. soft and comfortable.
so let me get this right... your only experience w/ tein s-techs was NOT with your 2is?
fyi, the spring rates for s-techs DO vary by model.
case in point, s-tech spring rates for the prelude and for the 2is:
while i am not an expert in suspension system physics, imo you're looking at a significant increase in spring rates. so while the s-techs for you prelude were "a little soft", then what's 1.5x-1.75x that?
your opinion is appreciated, but if you're going to make comparisons, make equal/fair (apples-to-apples) comparison.
thanks for reading.
thanks for reading.
IMO, H&Rs give the best drop .... to me, the most even drop you will get with springs! Also, Ive never heard anything bad about them from owners.... These are next on my mod list...
Here is pics for reference:
T-Rex06's car on H&R's:
thanks for reading.
thanks for reading.
Anywas, we are comparing springs to springs (not springs to windshield wipers) and most importantly the brand itself (like Hyundai).
btw, the inherent issue of comparing brands is each individual's perception of said brands. spring rates and reduced ride heights are facts. brand perception is an OPINION.
You don't see other members or myself saying anything about H&R or Eibach.
now, if you were w/ s-techs, and your experienced sucked, then yes, that qualifies you to say "s-techs for the 2is sucked for my 2is."
however, the most valid statement you can make based on your experience is "s-techs for the honda prelude sucked for my honda prelude." see the difference?
Although I use to be a Tein customer, they lost me as a customer since rep, quality/craftmenship, all personal reviews and experiences are everything again, in general not just on the 2genIS.
and since you continue to support your assumption without any real factual evidence, here's some MORE numbers to prove my point (that tein s-techs for the 2is are NOT soft):
spring rates f/r, N/mm (1 kgf/mm = 9.806 N/mm):
oem (linear): 45/47 (linear)
f-sport/eibach (progressive): 47/66 (normal), 40/70 (load)
tanabe nf210 (progressive): 48.0/56.9 (normal)
tein s-tech (progressive): 63.7/66.6 (load)
if anything, ^ shows that the spring rates for the tein s-techs for the 2is are right up there with some of the more popular offerings for the 2is.
soft? really?
thanks for reading.
can you guys post pics of IS with the different springs on 19's?? Those H&R's look pretty good. Are the teins lower??
I just want my car to look good. I drive like a grandma. I used to be a crazy driver (raced a M3 on I-10 with traffic up to 154mph on my 350z) But now everyone gets pist at me for how calmly i drive...
plenty of pics here:
https://www.clublexus.com/forums/sus...d-for-2is.html
you can find many more pics using the search function in the 2is suspension sub section using key words such as (but not limited to) "tein", "s-tech", "H&R", "f-sport", "tanabe", "megan", and "eibach".
best of luck with your search.
