DIY - Daizen Caster Arm Bushing Installation - lots of pics!
Old 01-15-13, 12:03 PM
  #166
pinoiryder
pinoiryder's Avatar
hello, its that time to replace my lower control arm and need suggestions,
1. Should i just changed the the bushing?
2. replace the complete lower control arm?
Also please post the part number for the sewell poly caster bushing or link.. Thank you for all the help.
Edit: I just called Sewell and was told that they do not sell the bushing by itself and i need to buy the complete lower control arm.. Please let me know if this is the case..
Old 01-18-13, 10:28 AM
  #167
StarkoS14
StarkoS14's Avatar
if the lca came with lower ball joints or something, Id say it would be worth it.. in the case of our gs', the only worn part that gets replaced with the arm is the bushing (and some fresh paint). Ive had poly bushings for a couple years now, Im happy with them. Plus, they were cheap! just do some extra shopping around! I think figs might even make poly bushings now too.
Old 01-18-13, 12:03 PM
  #168
B4TM4N
B4TM4N's Avatar
I would do whats listed in this thread:
https://www.clublexus.com/forums/7062204-post98.html
Old 01-19-13, 09:18 PM
  #169
FIGS
The Maker
FIGS's Avatar
I am working on this as fast as I can. All parts are out for quote including a camber adjusting version of this and the inner LCA bushing.
again the major benefit will be the improved fucntional design of allowing pivoting without requiring bushing distortion. Here is a diagram I made to demostrate this.
The install for the IS I just documented here in my blog http://figsengineering.blogspot.com/...aster-arm.html and once we get the new center tubes we should be good to go. I am making them for all years of GS and SC430.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Frankn (12-17-21)
Old 01-27-13, 06:24 AM
  #170
LudeNsoL
LudeNsoL's Avatar
I just want to update and say that my one year old daizen bushings are already clunking. Big let down. For future people don't wast your time getting the daizen bushings as they will start clunking again.
Old 02-24-13, 06:44 PM
  #171
whytry
whytry's Avatar
I'm in the market to replace mine as well. Where to get and any links or part numbers?
Old 02-24-13, 09:38 PM
  #172
FIGS
The Maker
FIGS's Avatar
We got our proto #2 bushings last week and if the new shop was online we would have a car on the lift verifying. But one more coat on the floors. I have parts for about 5 sets if everything works out fine.
__________________
Old 02-24-13, 11:21 PM
  #173
sakataj
sakataj's Avatar
so out with my spherical castor arms i just got made from you?
Old 02-24-13, 11:33 PM
  #174
FIGS
The Maker
FIGS's Avatar
no need for that at all. Keep the spherical bearings as they are a much higher level of function.
__________________
Old 02-25-13, 08:21 AM
  #175
sakataj
sakataj's Avatar
then what were you designing, for camber control, for me that you were talking about?
Old 02-25-13, 01:53 PM
  #176
FIGS
The Maker
FIGS's Avatar
That is the next version that will offer offset front control arm and caster arm bushings for camber adjustment. So I guess yes if you need camber adjustment then this would need to change. Its possible to reduce camber though on the on front bushing alone and pull back a little caster angle which is not a bad thing anyway.
Shoot me a call to discuss.
Mike
__________________
Old 02-25-13, 02:44 PM
  #177
sakataj
sakataj's Avatar
Mike
will do mike, right now im wrapped up into redesigning my stereo system for the 3rd time (damn you Vlad) i will try and call wed to discuss
Old 02-27-13, 05:07 PM
  #178
whytry
whytry's Avatar
I knew I had bought some of these at one time, cleaned some stuff up they are the ADUS 537's and they don't have anything in the package except the bushing no sleeves.... Since I have them already I think I'm gonna use em... Do I find a sleeve insert based on the others I've seen here or reuse the stock ones?
Old 03-05-13, 12:25 PM
  #179
BayAreaLex
BayAreaLex's Avatar
I'm glad to see that someone is making a 3pc design for the caster arm bushings. Way to go FIGS
Old 03-06-13, 08:54 AM
  #180
whytry
whytry's Avatar
Prob gonna do my lower ball joints same tie too
Quick Reply: DIY - Daizen Caster Arm Bushing Installation - lots of pics!
