DIY - Daizen Caster Arm Bushing Installation - lots of pics!
Old 10-09-13, 08:55 AM
  #211
FIGS
The Maker
FIGS's Avatar
Originally Posted by tmf2004
Mike, from the pics you posted looks like the inner sleeve doesn't fit the bushing? Looks to small unless its just picture.. Is that actual item in the pic?
That is the right part ( the center tube changes for the GS application), note that that is what makes these different, the center has a large radius instead of a fixed cylinder. The center tube makes a line contact with the donut and the 2 cap bushings hold it vertically, also holding the grease in the pocket.
See this image for better depiction
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 10-09-13, 03:06 PM
  #212
RikTT
RikTT's Avatar
Originally Posted by FIGS
Hi guys, finally have our design in as of today for 2001-2005 #2.
I've been in contact with Mike for AWHILE now on these and pleased to say they are enroute to me I'm overdue
Old 11-12-13, 12:01 PM
  #213
MasterKwan
MasterKwan's Avatar
LCA #1 is the one that connects from the engine cradle to the knuckle through the LBJ.
LCA#2 is the one the connects #1 to the chassis brace on the body. LCA #2 bolts to LCA#1 right where the shock mounts to LCA#1.
This picture is for #2.
Old 11-21-13, 10:56 AM
  #214
DosyBoy
DosyBoy's Avatar
I replaced my lbj's, inner tie rods, sway bar end links, brakes, rotors, tires, and I'm still getting a clunk over bumps, climbed under the car my bushings look like yours their like nothing left, all chewed away, this HAS to be my clunking problem over bumps, I'm ordering these this weekend can't wait!
Old 11-22-13, 07:10 AM
  #215
GSteg
GSteg's Avatar
Do it!!! I replaced mine recently and the car finally stays on track. They're MUCH easier to install than the crap Daizens I had. They're perfect for lowered cars. Thanks FIGS for making such a great product.
Old 11-25-13, 08:45 AM
  #216
SC4Paulo
SC4Paulo's Avatar
I drive a slammed GS400 would the figs be worth the extra cash compared to the other regular bushings out there? I know bushings are important but $155 for the castor bushings are a lot, I just bought all my daizens for $120 but I know the daizens aren't too great for the castor arm so I'm looking for a replacement that doesn't cost too much.
Old 11-25-13, 09:22 AM
  #217
GSteg
GSteg's Avatar
The FIG will be a much better. The GS is not a car you want to cheap out on. It's only $155 for parts that will last a lifetime. I had Daizen before and it was ruined due to poor design, yet I was lowered only 2" from stock.
Old 11-25-13, 01:23 PM
  #218
SC4Paulo
SC4Paulo's Avatar
yeah reason why I ask because I have heard the daizen's die in a couple years. I wen't over all my bushings in the car right now and they are actually all still good, so I may just take the car to the alignment place, see what their input on getting the alignment would be and if they say the bushings are still good, ill just run those until they die and keep the bushings for when they do start going out, previous owner has replaced them pretty recent, I saw my uppers were done when i threw my coils on. when my mechanic and I checked it out, we both saw that there isn't much play, the wheel was just not centered.
Old 12-10-13, 09:27 AM
  #219
silverbul
silverbul's Avatar
Hey guys. I think I mite have the answer to the clunk. I have a silver 98 GS400. I've replaced every front end component that you guys mention. Upper, both lower control arms, sway bar links, rack bushings, lower ball joints, experimented with daizen bushings & still had the clunk. My clunk went away 2yrs ago when I replaced my rack & pinion. Then after replacing the rack, found out inner tie rods will cause clunk. Still to this day & 238k miles later. Still running strong & no more CLUNK!
Old 12-12-13, 09:11 PM
  #220
DosyBoy
DosyBoy's Avatar
So do I leave a note on sewell stating W/SLEEVES!!!! ?
Old 12-13-13, 11:19 PM
  #221
cenzo
cenzo's Avatar
Hi, new here, but I've been reading this whole thread because I believe I have the 'ol caster bushing symptom. I kinda saw it coming as I've seen the bushing slowly get worse over time but I just haven't had the time to verify just yet. Will definitely verify before I do anything but I'm just planning ahead for the near future.
GSteg -- FIGS 4-piece urethane worked out great? Did you install the FIGS 4-piece into the arm first and then install the arm in the car? (asking in case there was a chance that you installed the arm in first, then installed the FIGS 4-piece into the arm to avoid difficulty--though I'm not sure if it can be done that way?) And how easy?
(I'm debating whether I should go w/ FIGS 4-piece or Sewell arm w/ pre-installed bushing cause I kinda need to have it done in one shot, in and out of the shop in as little time as possible. I'm also trying to avoid re-installation difficulties when putting the caster arm back in, as I've heard other DIYers have had. Anyone found a quick-and-easy to install a Sewell caster arm w/ pre-installed bushing?)
Also, thanks to all those that have contributed to this thread, and to original post.
Old 12-17-13, 09:34 PM
  #222
GSteg
GSteg's Avatar
The arms must be removed in order to install the FIGS. You have to press out the old bushings.
The Sewell is the same design as the Daizen and pressing these bushings in is a heck lot harder than the FIGS. The only advantage the Daizen has over the FIGs is the price. Other than that, there is no reason why you shouldn't spend a bit more for a better engineered part. Honestly, the Daizen felt harsh and I expect the same for the Sewell bushings. The FIGS feel closer to OEM than the Daizen. Sometimes I forget that I have polyurethane bushings just because they allow deflections rather than having all that energy transmitted into the cabin.
When I installed the arms back into the car, I removed the lower shock bolt so the suspension can move freely. Disconnect one end of the sway bar too.
Old 12-17-13, 10:04 PM
  #223
runyun
runyun's Avatar
^ Thanks again Henry for answering my questions. Because of you, I went ahead and ordered some FIGS bushings just now
Old 12-17-13, 10:14 PM
  #224
GSteg
GSteg's Avatar
Pressing the FIGS in is a piece of cake. You'll have it done in no-time.
Old 12-18-13, 06:44 AM
  #225
sakataj
sakataj's Avatar
it is simple to install them
https://www.clublexus.com/forums/sus...-bushings.html
Quick Reply: DIY - Daizen Caster Arm Bushing Installation - lots of pics!
