DIY - Daizen Caster Arm Bushing Installation - lots of pics!
Old 05-21-17, 04:13 PM
  #271
GSteg
GSteg's Avatar
The shop could have easily removed the bushing by using an air hammer and hammering in metal sleeve until it mushrooms inward. They will press out easily this way. Takes me less than 5 minutes per arm.
It's been years since I did the bushing install but what I did was remove the lower shock bolt and loosen the three top nuts so the whole knuckle moves freely. If you can remove the entire shock assembly then that's even better. The point is to get lower control arms to move freely so you can wiggle things around. Use a wrench to maneuver the caster arm and place a jack under the knuckle if you need to raise the assembly.
Old 05-21-17, 04:48 PM
  #272
lyonkster
lyonkster's Avatar
Originally Posted by RamAirRckt
Anyone have tips to make it easier to line the bolts up the arms better? Usually I fight with it to get it in, but coming out is a piece of cake.
I also struggled with that quite a bit, I think loosening the ball joint might have provided more play and made things easier.
And can anyone restore the photos in the first post?
Done. .
Personally, if I did it again, I'd just get new OEM arms from Lexus and put them in. All this bushing pressing and swapping is just not worth the effort (for me). But to each their own, and it was a fun project at the time .
Old 05-21-17, 06:29 PM
  #273
lexo98
lexo98's Avatar
Done. .
https://m.youtube.com/watch?v=Twt47cvQFjY
LexusK (05-24-17)
Old 05-21-17, 09:23 PM
  #274
RamAirRckt
RamAirRckt's Avatar
This was factory 1998 arms, very rusted (Minnesota car that has been "down south" in Chicago area for the last 7 years or so). It wasn't gonna come off with an air hammer without damaging the arm. The machinist was in his 70's and cussing away because it was so tight. Crazy tight. Even cutting it with a saw to break the tension still took a lot of work to get the shell out. It was in there and determined to stay.
The press he used was one he made, a hydraulic press (20t) that had a hydraulic pump on it with foot pedal control. It was slick. Going in was a piece of cake, but tearing it down was TOUGH.
The beauty? He charged me $10.... for both arms!
tiguy99 (06-01-17)
Old 08-14-17, 07:51 PM
  #275
Maltrix
Maltrix's Avatar
So is the overall conscientious that the Dazien bushing kit isn't good? My recent GS430 came with the kit for the front and I was thinking about installing it since I have it. But seeing as it might develop a clunk and the rubber up front(think PO installed some moog parts in 2015) is in decent shape IDK if it's worth it.
Old 09-09-17, 07:19 AM
  #276
Maltrix
Maltrix's Avatar
Alright so im going to put these in anyway.If it develops a clunk down the road ill deal with it then. Someone mentioned NOT removing the the inner ring with the bushing as instructed by the OP. But that's in the instructions so I dont think that would be an option. I'm wondering if there is a cheap/easy way to sure up the slack with the sleeve and stud? Perhaps some kind of adhesive tape or maybe JB weld/epoxy? Or was the slack purposefully designed to allow some articulation?Just trying to get some ideas it's kind of an interesting challenge to me.
Old 09-09-17, 07:25 AM
  #277
Maltrix
Maltrix's Avatar
I also have new Moog UCA to install. Something in me doesn't like the idea of replacing brand new rubber lol. Is it worth it to pop out the bushings and install the poly ones? If I dont ill have poly on the caster arms #1 and #2 and rubber up top. I have already replaced the sway bars and power steering rack with Daizen so I don't really know if the UCA will make any difference.
Car is still new to me and I'm just trying to get ride of the 60+mph shake. Don't really need the car to handle like a BMW but dont know how it handles stock vs all poly vs a combination of the two.
Old 12-22-17, 04:03 PM
  #278
AL1963
AL1963's Avatar
just did the front left after reading the thread. I cut the metal sleeve and air chiseled the bushing out. Used a 12 ton press to put new bushing in place, I bought Febest # TAB-187 OEM 48670-30280 off ebay for my 2004 GS300. Then I jacked up front of car slowly until the bolt holes lines up . Didn't need a wrench to twist the arm to line up the holes. thanks for the thread and pics.
Old 01-20-18, 03:04 PM
  #279
whitelex43
whitelex43's Avatar
Just attempted to replace my 4 year old Daizens with Figs bushings, unfortunately the mechanic that installed the Daizens cross threaded my control arms. I threw the Figs I bought on ebay and am going to install OEM arms from 03-05 as they are supposed to be TRD bushings in them. Can anyone confirm this?
Old 01-20-18, 09:19 PM
  #280
pizdets17
pizdets17's Avatar
I've had my Daizens for 6 years. No clunk.
Old 01-30-18, 03:59 AM
  #281
whitelex43
whitelex43's Avatar
After going from 4 year old Daizens to the 03-05 OEM arms my overall impression is a much smoother and more compliant ride. Very happy with the improved ride quality, handling did not suffer at all.
Old 02-02-18, 06:22 PM
  #282
anbkpl5
anbkpl5's Avatar
Man you have been a huge help. Lexus in Dallas was going to charge me $1400 to do this for a $55 part that I can do myself. Thanks for your help brother.
Tony
'04 SC430, Twilight Amethyst
'07 ES350, Silver
'10 LS 460L Black
"05 ES330
Old 01-07-19, 09:35 PM
  #283
salimshah
salimshah's Avatar
Received 1,078 Likes on 970 Posts
Done. .
Just installed mine today. Bought them from metro1969 and the package was delivered in 2 days. New Lexus/Toyota parts are beefier.
Struggled a whole lot (almost 45 minutes) with extra jack and then reached out for the 18" adjustable wrench. Grabbed the arm close to the rubber bushing and with minimal twist the holes lined up. I could thread by hand both the long bolts by rocking the adjustable wrench. Will be making alignment appointment.
Salim
lyonkster (06-19-19)
Old 11-15-19, 02:24 AM
  #284
Delp
Delp's Avatar
Hi there I'm from U.K are there any suppliers in the u.k?
Old 11-15-19, 11:31 AM
  #285
captainva
captainva's Avatar
Look for Superpro bushings. They're better quality and have much better customer service
Quick Reply: DIY - Daizen Caster Arm Bushing Installation - lots of pics!
