SPC Front camber + Megan rear suspension rods install photos + results
Old 04-21-10 | 01:32 PM
  #31
B16da9's Avatar
B16da9
Update, I bought the balljoints through this place http://importautoperformance.com/pro...cat=355&page=1
SPC wanted $102.00 per ball joint plus shipping. This place had them for $165.00 for the pair with free fed-ex ground shipping.
Old 04-21-10 | 06:25 PM
  #32
Pnuge88's Avatar
Pnuge88
link no worky. if this is a legit fix i'm in for it. say no to negative camberr
Old 04-22-10 | 12:10 PM
  #33
fknISC808's Avatar
fknISC808
link works for me.
Old 04-22-10 | 12:41 PM
  #34
andrewshu3's Avatar
andrewshu3
well, ive had mine for about 300 miles now. no issues
Old 05-13-10 | 10:47 AM
  #35
JDKane527's Avatar
JDKane527
CL Folding 25,000
Do you think these front ball joints will be any less durable than oem? Considering to perfect front, but IIRC my front wasn't too badly out of spec, just that it could be improved haha.
Old 05-13-10 | 11:03 AM
  #36
B16da9's Avatar
B16da9
I think they will be just as durable as the oem ball joints.
Also when I get home today I will post pictures of my ball joint installation. I installed them two weeks ago and no problems.
Old 05-15-10 | 10:41 AM
  #37
KI_GSE21's Avatar
KI_GSE21
Please post a quick writeup and some pictures would be nice. I am also considering the SPC front ball joints to fix my front camber issue. Many thanks!
Old 05-17-10 | 04:43 PM
  #38
ToniS250's Avatar
ToniS250
Just the curiosity , did you paint or put a clear coat on ur rims? they look awesome mines r just plain silver
Old 05-17-10 | 05:12 PM
  #39
kevenhang's Avatar
kevenhang
I wonder if these fit AWD model??
Old 05-17-10 | 07:07 PM
  #40
B16da9's Avatar
B16da9
Here are the pictures of mine installed.
I was able to set the camber to .04 L and .05 R by an angle finder and a level. My friend that aligned the car for me set the toe at a optimal setting for tire wear. I've also posted a picture of my car so you guys get an idea of how low I am.
The tool below makes separating the ball joint from the spindle a walk in the park. If you use this tool make sure that you only loosen the castle nut DO NOT REMOVE IT. If you use the tool without the castle nut
reinforcing the tip of the ball joint stud it will mushroom the end and you will not be able to reuse it if you
ever want to go back to stock.
Also some people use the method in the picture below. Heck I even use that method on my Integra but
those spindles are iron not aluminum like on the IS. I you use the hammer you will damage something.
Stock ball joint out, it was very easy to get out. Then again I have a lot of experience working on cars.
Old 05-17-10 | 07:36 PM
  #41
laobo979's Avatar
laobo979
they should since the only thang diff is that the front axle and c-bracket on the shock to clear the axles for the AWD front. the rear is the same setup as the RWD
Old 05-27-10 | 12:50 PM
  #42
llhelix's Avatar
llhelix
Interesting B16da9, you didn't have to shave off a little of the outer lip on the upper arm to allow the sliding mechanism to work correctly? I just installed mine on my IS350 this past weekend and I had to grind off about 2-3mm similar to what andrewshu3 stated in his original post.
Had my alignment checked after the installation and camber is finally comfortably in the green!
Old 05-27-10 | 05:04 PM
  #43
andrewshu3's Avatar
andrewshu3
it doesnt look like the mounting plate is properly mounted on your upper arm.. did you hammer it in so the crown is holding the plate flush to the inner surface?
if not, you risk damage to your upper arm down the line.
Old 05-29-10 | 01:04 AM
  #44
hidfanatic's Avatar
hidfanatic
So with this setup, how adjustable are the fronts? Like how much -camber can be achieved?
Old 06-01-10 | 08:17 AM
  #45
B16da9's Avatar
B16da9
I did grind it off you just can't notice it in the pictures as I painted the arm with black BBQ paint so it does not rust
Those pictures where taken before I tighten down the top nut.
