SPC Front camber + Megan rear suspension rods install photos + results
#46
Originally Posted by B16da9
I did grind it off you just can't notice it in the pictures as I painted the arm with black BBQ paint so it does not rust
#47
So I decided to open the rear LCA mount hole bigger and sliding the arm in to fix the camber. This is exactly what Miami Chassis does.
Use this grinder with stone bits
Hole opened up.
Bolted up and slide in.
Hole opened up.
#49
they will allow you to correct camber, or to obtain more camber, depending on what you do to your car. these are not needed in order to "HellaFlush" your car. If you want it to look a certain way and really call your car HellaFlush" then yes, these are essential pieces to go with your drop.
#50
^ thanks dude. i dont know how to explain the stance i am aiming but i want something similar to chrIS250 when he had his SSR SP1.
i'll keep that in mind. i read somewhere here that having camber kit reduces the uneven tire wear..but m not sure with the suspension rods. i assume they help on maintaining the correct camber since they are adjustable, yes?
#51
#57
pretty straight forward, have a few of those grinding bits ready. they wear quick if you dont keep the grinder moving. I opened the hole up until the edge of the bolt head. you can see the mark on when you take the bolt off.
#58
The Maker
should be releasing my arms soon as well for those that want to wait. I would also add that camber is less important that proper toe correction. I am running -2.2 on the ISF and still have flat tread wear in the rear. I have new toe links installed that maximize arc length and reduce the amount of toe steer on bumps. Its all about the dynamic system behavior, not just the static alignment.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
#59
The rear control arms for the IS300 have adjustable camber. If you're looking into making your rear camber adjustable, use the camber bolts and control arms for the IS300. Yeah, the ISx50 uses 5-link rear and the IS300 use wishbone rear but the rear control arms are adjustable.
Also using any sort of spherical rod end will be a harsher ride and will wear out from the dirt and grime getting in. You may use a teflon reinforced inner race equipped rod end (which costs more) but it too will eventually wear out.
#60
The front caster is not adjustable but there is a positive 0.5 deg and negative 0.5 deg lower bracket that can be purchased. I've replaced both my front caster brackets with 0.5 deg positive brackets.
I've been eyeing the IS300 SPC adjustable ball joints for a while. Its good to see someone has already used them with success. I'm debating about installing a set on the next set of tires I'll be purchasing.
