SPC Front camber + Megan rear suspension rods install photos + results
#91
These arm are a negative camber solution, not a positive one. There is no additional room in the UCA to remove camber...its a tight silhouette of the control arm.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
![](https://www.clublexus.com/forums/signaturepics/sigpic106840_3.gif)
#94
note, see my above statement about correction. My arms will not be able to do much with camber by pushing out the top. No room.
__________________
#95
Has anyone measured the taper on the IS300 vs. IS350 ball joints? I may have a set of IS300's laying around. I'll try to get them measured this week.
I'm having this same debate right now. Hopefully someone will step in and help us ISx50 owners out.
#96
I have measured them and they are different per my previous post. I was mostly curious as to how there were no issues with this brought up.
__________________
#98
I got the SPC ball joints this week and want to install today but have a couple of questions. Does anyone know the torque specs for the upper control arm? I know it needs to be removed to remove old ball joint but cant find the torque specs to reinsall. Also, how about the torque specs for the nut on the ball joint with the cotter pin? Thanks
#99
48076-30040 OFFSET:+20,
48076-30050 OFFSET:-20,
48076-53010 OFFSET:0,
Right bracket
48075-30040 OFFSET:+20,
48075-30050 OFFSET:-20,
48075-53010 OFFset:0,
If you need to get ahold of me you can reach me on my email in my sig. I'll can send you my number via email if you need to contact me.
TIA
-Joe
#100
I am getting even closer on my UCA design and should have all the final parts in a few more weeks. Sorry its taking so long. Things are on order though.
Fig
Fig
__________________
