Daizen Bushings
#48
Any pictures of what comes in the complete kit?
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
![](https://www.clublexus.com/forums/signaturepics/sigpic106840_3.gif)
#49
yeah mike....
this is from TM's website and he is a daizen distributor. (dunno if this pic is a generic pic or the actual components)
http://www.tmengineering.net/images/...controlarm.gif
y u gonna finally step in and make something for us to avoid this hassle? i might be willing to send you my DAIZEN bushings if/when I EVER get them or i guess u would actually need a car to prototype something on?
if mike steps in, it will be something good
#52
Hmm, I am not sure if that is the end application. On the IS, its two mounts on one side and a clamshell mount on the other. I gotta find a GS to crawl under now ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Edit, these are the lower control arm bushings or the steering rack bushings? The link says control arm.
__________________
#55
![](http://i88.photobucket.com/albums/k195/Figbline720/suspension/PF_PU_Sphericals3_1000.jpg)
![](http://i88.photobucket.com/albums/k195/Figbline720/suspension/PF_PU_Sphericals4_1000.jpg)
__________________
#56
Based on how they look, its not a good replacement for the way the bushing actually gets used...especially in the caster position since its guaranteed to rotate and compress. I will get something for you guys. I have the GS arm that I bought to do this and the complete IS front. While the arm geometry is slightly different, the bushings are the same I believe. I got a plan of attack now.
Fig
__________________
#58
If you were to just produce these bushings, the way they are..you would make moutains of money if you can keep up with the demand, that the original manufacturer of them cannot.
