SC 300 break system
I am not sure that you can without some modification, could be more trouble/expense than it's worth. Many people just go with the LS400 BBK from a LS400 1995-2000, and they do an outstanding job of stopping the SC. I have an extra set of LS400 front calipers that I may sell. Email for pics: draytonwebb@yahoo.com
It has nothing to do with stopping, but more so with cooling.
The stock brakes work fine with the right pads.
But they will overheat sooner being as how they have less surface area and dissipation.
Also, what difference does it make if the Supra has 1000hp or 200hp? Weight is weight.
If you're wondering about the weight difference, Supra's and SC's are only about 100lbs apart.
I was stating that if the stock brakes on a Supra have no issues slowing them down from 160mph, road racing, canyon runs, etc. Not to mention they are quite cheaper, why not go with the tried and true conversion and stay practical?
Mainly... until your car has the ability to outperform your brakes, no need to go overboard.
Like putting a parachute on a stock Civic Si.
nothing to do with stopping - in that case go and put some pushbike brakes on your car.
overheat sooner with less surface area - so camry brakes overheat before soarer brakes braking for the same corner.
weight has 20% got to do with it.
sc400 276mm brakes have more clamping force than 320mm supra tt brakes
sc400 have an engineering limit of 500hp
sc300 have an engineering limit of 650hp
supra tt 4 pot have an engineering limit of just over 1000hp
Lets say your car is putting down a blistering 208hp to one wheel...
You round a corner and there's exactly a ½ mile ahead before the next corner.
A 1000hp Supra rounds that exact corner moments after you.
The Supra will reach a much greater speed and still be able to stop fine way before the next corner. As oppossed to your car that cannot reach nearly the same speed in the same amount of space.
So, why do you need brakes that are better than the Supra?
dwebb99
SC400 / 300 Classifieds
02-20-12 06:18 PM
ifilrx
Maintenance
11-14-05 12:34 AM
