Should I wait to install coils and rims at the same time?
So I'm planning to get coilovers and rims sometime in the near future. Can I install the coils now with my stockies and put on the rims later or would that involve extra cost (e.g. a second alignment after the rims go on)?
alignment will be needed after coils are installed..if you change the ride height with your new wheels then you probably will have to get the alignment checked again..usually a reputable shop will give you at least 1-year alignment warranty so if you get your wheels within a year of the alignment then you can take it back to them to check the alignment..
hey brociouz. i waited and went with coils n wheels at the same time. you do save on the alignment cost, but also u get everything knocked out at once. I'm a lazy guy, so i rather wait then to go to the alignment place 2 separate times. But go drop first before wheels if u want to do 1 at a time =)
I'm open to recommendations, but am leaning toward BC Racing or TEIN CST (the latter probably being too expensive). I want to keep the ride quality as close to stock as possible, which rules out the TEIN SS Coilovers. I've also ruled out Megan because of the pillowmounts that replace the stock rubber. Any others I should be looking into?
mrshabo
Suspension and Brakes
10-24-04 11:34 AM
