Old 12-12-14, 03:49 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Print Wikipost
Replace shock mounts?
Old 03-31-10, 01:52 PM
fasted1953
fasted1953's Avatar
Default Replace shock mounts?
Trying to decide whether to replace my front upper shock mounts or not. 99 GS400 with original struts and everything else in the front suspension and steering. I did recently replace lower ball joints, camber arms, tie rod ends. I'm going to do shocks in the near future and am wondering if it makes sense to replace the upper mounts just because they're old. Likewise for the spring/shock bumpers.
What do you think? I'll be paying for this work, not diy like the lbj's etc.
Old 03-31-10, 03:56 PM
PHML
Master Thread Closer!!
PHML's Avatar
whats wrong with your upper shock mounts?
Old 03-31-10, 04:10 PM
ZippyGuy
ZippyGuy's Avatar
If you're going to replace the shocks/springs, it just makes sense to replace the strut mount. They DO deteriate over time so you'll see advantages (less noise). At least for me, anytime I get into something like the strut assembly I replace and/or upgrade what I can to enhance the ride.
A good shop should not charge you any appreciable amount for replace the mounts, as a matter of fact, if you're replacing the shocks it makes the job easier replacing everything at once.
Check out this DIY which shows how replacing the strut mount with the assembly makes sense.
https://www.clublexus.com/forums/sus...n-install.html
Old 03-31-10, 08:07 PM
fasted1953
fasted1953's Avatar
There is nothing wrong with the shock mounts as far as I know. Just wondering if its a good practice on a 10 yr old/96K mi car thats getting its first strut change. The shock mounts arent cheap, so wondering if it makes any sense to do it. My goal is to get it as close to original condition and performance as I can. Best car I've ever owned and I plan to keep it running well as long as I can.
Old 03-31-10, 09:24 PM
ALeX300
ALeX300's Avatar
i replaced mine since i didn't want to change struts, ball joints and bunch of other front suspension bits and STILL have annoying squeak. KYB makes em. Shop around. $92-105 shipped for 2 front strut mounts model is sm5205.
persian451
Maintenance
16
02-23-18 03:15 PM
SC3coupe
Suspension and Brakes
10-31-13 11:21 AM
lexusben
11-01-12 09:12 AM
HGill
02-23-11 12:12 AM
mrekid
RX - 1st Gen (1999-2003)
11-20-06 10:48 AM
Quick Reply: Replace shock mounts?
