What else to replace when doing springs / shocks /struts?
I'm looking at replacing my springs / shocks / struts, and since i'm down there, is there anything i should replace suspension wise, that maybe worn out.
Please provide links on where to buy and what i should replace
thanks
thanks
How many miles do you have on your car? The front lower control arm bushings are notorious for wearing out and seriously degrading ride quality. The rear CA bushings wear too, as well as the front upper CA bushings, but they seem to take substantially longer to get to the condition of the lower fronts. Steering rack bushings might be a close second. All these are searchable here.
The cheapest so far for rack/pinion steering bushing set is from Daizen at around 40 not including shipping: http://www.tmengineering.net/suspens...n/make/sc.html . However, prothane sells the suspension bushings front and rear for much cheaper. FRONT: http://performance.yoparts.com/i-142511.aspx REAR: http://performance.yoparts.com/i-142524.aspx
-Nick
-Nick
1JZ Single SC400
The rear upper control arm bushings are a PITA to change. If you decide to this, I would lower the whole rear subframe of the car. Its real tight in there. Its what I did and made life alot easier, if you have the tools and jackstands.
Ahheck01
Suspension and Brakes
01-12-15 06:27 PM
fabioso10
09-12-08 06:49 AM
akitamike
07-09-06 03:47 AM
