Coilovers + winter = BAD?
Old 04-01-10, 09:09 PM
dappy
dappy's Avatar
Default Coilovers + winter = BAD?
I was wondering if winter driving with coilovers will cause the collars to seize, thereby making height adjusting difficult? Those that have gone driving in the snow, what are you opinions on this? Any problems with your coils? I'm interested in knowing since I just upgraded my suspension from Eibach Prokit to JIC FLT-TARs.
Do you guys raise your travel height up during the winters and then lower it in the spring? Coilovers are new to me, so I just want to become more knowledgeable on it.
Old 04-01-10, 09:47 PM
lexboi250
lexboi250's Avatar
I was just gonna start a thread on this, I'm curious about this too.
Old 04-02-10, 07:54 AM
datplayaz
datplayaz's Avatar
On my previous cars I've had a couple of sets of coilover seizing up on me over the winter making it harder to adjust then eventually it was fully stuck so I ended up getting another set, but what i'm trying this year is to wrap up the coilover where the threads are with plastic and then wrapping it with duck tape to prevent most of the water/dirt/salt. I'm tempted to try these next winter.
http://www.kirkeyracing.com/index.ph...20Over%20Cover
Old 04-02-10, 08:31 AM
mdgrwl
mdgrwl's Avatar
I just went through one of the worst winters here with my BC Racing coilovers and no problems. I was just adjusting my ride height the other day for my 20's, no locking at all.
I would cover them if you are worried about it, pretty easy fix.
I keep my ride height the same year round too. If there's so much snow on the ground that my ride height will effect my driving, I wouldn't be out on the road anyway. Usually after the plows do their job its drivable within a day at max.
Not worth getting a new alignment twice a year in my book.
Old 04-02-10, 08:46 AM
pchan0
pchan0's Avatar
I have a set of BC coils on my AWD and went through the winter in Toronto no problem. Adjustment rings did not seize.
Oliver, did you install your coils at speedstar?
Old 04-02-10, 11:05 AM
CircuitMS
CircuitMS's Avatar
A good bit of advice if you drive through salt and stuff is to make sure you coat your threads will anti-seize or a light coat of grease before you adjust them, that way the threads are proected where they meet the adjustment rings.
Old 04-02-10, 07:40 PM
laobo979
laobo979's Avatar
im threw my second winter with my coilover but before i adjust them i spray the sleeve with wd40 and use a brush to take the dirt off and then i adjust it back down for the summer
Old 04-02-10, 09:36 PM
dappy
dappy's Avatar
Could you wrap it in plastic cellophane? Thanks for the tip.
Originally Posted by pchan0
I have a set of BC coils on my AWD and went through the winter in Toronto no problem. Adjustment rings did not seize. Oliver, did you install your coils at speedstar?
Got them installed at APH. Glad to hear you made it through the winter Peter with your BCRs. But, then again we didn't get much snow.
Yup. Did that during the coilover install.
Awesome!
Old 10-07-10, 04:48 PM
BounceNY
BounceNY's Avatar
This has probably been covered, but I'm still unclear how to raise the ride height. I know the lower ring needs to be adjusted, but I could not get it loose. Do I need to adjust any of the top rings that preload the spring? I've only had the coilovers for 2 weeks so its not rusted or anything.
Old Today, 02:22 PM
lazyfsport
1st Gear
lazyfsport's Avatar
Hey! Can you please share the year/model of your IS? I am interested in BC coilovers and could not find anything for 2018 IS350 FSport. AWD. Thanks!
halfnyce07
02-12-16 10:52 AM
halfnyce07
Suspension and Brakes
02-07-16 03:04 PM
scott1256c
12-21-13 09:49 AM
Lexusfam
NELOC
05-05-11 06:14 AM
Chigga
01-22-05 09:43 AM
Quick Reply: Coilovers + winter = BAD?
