Could RCAs fix this problem?
Old 04-05-10, 06:35 AM
Automan
Automan's Avatar
Default Could RCAs fix this problem?
I have UAS bags over TEIN CS coilovers and my front end has never gone all the way down in the front. It looks like it should be able to go down another inch or so. Would installing RCAs fix this issue?
Old 04-05-10, 07:15 AM
GSteg
GSteg's Avatar
Yes, adding RCA will drop you even further depending on how thick they are. If the RCAs are 1", you'll drop another inch.
You do risk the possibility of having the upper control arm balljoint hit the upper part of the fender, but of course there are fixes for that.
Old 04-05-10, 07:19 AM
Spyder78
Spyder78's Avatar
Automan as I said in ur thread on vsc, I think that your suspension is setup incorrectly. I'm finishing the install on my friend's car with the tein CS on Thursday and I will show you pics of the drop and help you correct your issue if I can.
Old 04-05-10, 08:40 AM
Automan
Automan's Avatar
Thanks I would appreciate it.
Old 04-05-10, 09:51 AM
rgarjr
rgarjr's Avatar
Yeah it will drop more, but you will lose lift as well. Which means you will need to ride with a bit more pressure in the bags.
Old 04-08-10, 05:05 PM
PHML
Master Thread Closer!!
PHML's Avatar
good point about the bag psi with RCAs.
Old 04-08-10, 10:43 PM
rgarjr
rgarjr's Avatar
Yeah and if your riding with a lot of PSI in them, your ride will be stiff. So it all goes into play.
JDMmanny
08-07-11 07:22 AM
lilsharky
Suspension and Brakes
08-19-09 09:10 AM
KevMMA
05-10-08 10:35 PM
edfrsd
16
05-01-07 10:36 PM
L3XUSGS400
17
07-22-06 08:48 PM
Quick Reply: Could RCAs fix this problem?
