Rear Brakes & Rotor Noise
I just recently changed my rear brakes and rotor. Everything seems to be fine but when i make a left turn i hear a metal to metal scraping noise coming from the right rear. Does anyone know what the problem might be?
1998 lexus gs 300
1998 lexus gs 300
I'm not sure if this is the same problem or not but I just recent had a intermintent squeek on the pass rear. Turn out there was rust on the inside of the rotor was was causing it. Make th hoses aren't turned around or look for any fresh scrapes on the pads or the rotor. When your looking at the inside of the rear rotors you remeber the pad surface around the rotor and ebrake surface on the inside there is a little ridge that sometimes if the spacing isn't enough it causing rubbing. I just returned a set of rotors for that very reason yesterday which is why I searched. Anyways, good luck.
rling
11-04-18 12:20 PM
nysimonsez
Suspension and Brakes
11-13-10 06:37 AM
