Best Place for LBJ's?
Old 05-02-10 | 10:36 PM
PHML's Avatar
PHML
Master Thread Closer!!
Originally Posted by Caoboy
Problem 2. I went to put everything back together, after replacing the LBJ anyway (might as well since I have the parts, right?) and the UPPER control arm Ball joint is SPINNING! thread the nut on there, and the stud just starts spinning in the UCA
A) Is this bad, can it be fixed?
or B) Do I just need to order UCA's now?
Just press the ball joint to the upper arm...it wont spin after that.
Old 05-03-10 | 01:31 AM
Caoboy's Avatar
Caoboy
Ahh ok thanks guys. I'll try to work on it again tomorrow and try that out. Scared me for a min there!
Old 05-03-10 | 03:29 AM
kit cat's Avatar
kit cat
LBJ just sounds weird...
i am so immature lol
Old 05-03-10 | 02:50 PM
Caoboy's Avatar
Caoboy
Jeeze, always have SOMETHING on the brain eh?
Old 05-19-10 | 06:08 PM
NewNorth's Avatar
NewNorth
Havent been able to get the promo code (clublexus) to work on Sewell for the ball joints. Anyone else having this problem???
Old 05-20-10 | 12:38 PM
sakataj's Avatar
sakataj
the new sewell website u register and include your CL name and it applies automatically....
Old 06-02-10 | 08:58 PM
Caoboy's Avatar
Caoboy
So I finally replaced my lower ball joints, car feels better.
First I replaced the right side, and didn't have time to do the driver side. Wrong move. Car started clunking WAY more for some reason. I guess the geometry was messed up even worse. Fixed the Driver side today, I'm getting really quick at tearing apart the front end lol!
Car feels a lot better, but I'm still getting a clunking noise. Not bad, clunking only happens when it hits a pothole or bump in the road that you would avoid if you were low with nice wheels.
So...next up to replace are the tie-rods, and the bushings. Tie-rods should be put in on Friday, I can't for the life of me get them off, so I'm having a shop do it. I'm thinking I should just replace the giant caster bushing, is there any benefit to replace the other bushings? I am on the fence about having to tear apart the front end AGAIN lol!
Hopefully the clunking stops after these, only other thing I can think of that would make the clunking sounds over bumps would be a dead shock.
Old 06-02-10 | 09:43 PM
GSteg's Avatar
GSteg
What's wrong with the tie rod that you can't them off? Which part is stuck?
Old 06-02-10 | 10:02 PM
Caoboy's Avatar
Caoboy
I think it is mostly that I do not have a lift, and cannot get enough leverage to break the nut loose, and break the tie rod loose. That, and road grime, stuck nuts from not ever being touched probably.
Old 06-02-10 | 10:28 PM
GSteg's Avatar
GSteg
Use an adjustable wrench and a mallet/hammer. Always works for me.
Old 06-02-10 | 10:53 PM
Caoboy's Avatar
Caoboy
Believe me, I've tried...Used a 19mm wrench, one on the tie rod, one on the nut, locked the one on the tie rod, and banged away at the nut wrench. It didn't budge. It shouldn't be too much, the mechanic hooks me up, he's a friend of my GF's father.
Old 06-03-10 | 12:01 AM
GSteg's Avatar
GSteg
Use your foot. No need to hold the tie rod down. Just give it a strong kick and it'll loosen up. Maybe you're turning the wrench the wrong way
Old 06-03-10 | 12:41 AM
sam430's Avatar
sam430
No way it should be that difficult unless it's welded down. It should be very very easy to take it off.
kalisun87
Suspension and Brakes
02-17-19 06:51 AM
Nguyen07
13
01-15-15 10:52 PM
mattjk
05-13-13 05:22 PM
GenOneGS
03-08-13 05:48 PM
DarrellGS4
09-06-05 03:29 AM
