Those who installed BC Coilovers
Old 04-15-10 | 10:18 AM
imports4me's Avatar
imports4me
Default Those who installed BC Coilovers
Hey guys,
This weekend i will be attempting to install my bc racing coilovers. i will be doing this with my cousin who is pretty good with kind of stuff. He changed all his cars including the 10 GTR. anyways, i just wanted some feedback as to, is there anything i should look out for? as to do's and don'ts, and also other then your normal tools, is there any special tool that i should go and buy or rent, like spring compressors?
also, with the settings, ive been doing some research but reviews are all over the board. i guess my kit came with the 10k/8k. what settings should i use to have a good ride.
thanks for your help
Old 04-15-10 | 11:57 AM
nMeOnE's Avatar
nMeOnE
I used 6 clicks in front and 4 in rear and it rides pretty soft. Almost like stock!!! almost! Dont forget to torque down your lug nuts after your coilover install instead of just hand tightening it like i did! lol good thing i caught it before my damn wheels fell off during the half a mile test drive.
Old 04-15-10 | 12:05 PM
ExTrEmE99's Avatar
ExTrEmE99
Check your spring preload, check if all the bolts are tightened etc...
Old 04-15-10 | 12:31 PM
imports4me's Avatar
imports4me
thanks guys...anymore? so no big tool items that i may not have in the garage is needed. i hate starting something and not being able to finished due to a needed tool.
Old 04-15-10 | 12:59 PM
projectdna's Avatar
projectdna
if you're re-using the oem upper mounts, you may want a spring compressor so you don't have parts flying everywhere when you unbolt the upper mounts from the shock assembly. at least i think that's what you might need.
as far as settings for a "good" ride, start out with middle settings and dial in a firmer/softer ride as desired.
Old 04-15-10 | 02:24 PM
imports4me's Avatar
imports4me
i have no idea, i ordered the bc racing coils so i dont know if ill be using the oem mounts.
anyone can confirm this?
Old 04-15-10 | 02:35 PM
ExTrEmE99's Avatar
ExTrEmE99
You wont need to use any OEM parts off the shocks/springs.
Old 04-15-10 | 03:05 PM
Mv350's Avatar
Mv350
the 2 bolts under the hub, undo those, makes everything 100x easier easier to take stock stuff out on the front, the rears its not nescery
Old 04-15-10 | 03:35 PM
mybablex's Avatar
mybablex
Should we reuse the oem upper mount?
Old 04-15-10 | 03:43 PM
ExTrEmE99's Avatar
ExTrEmE99
You will not reuse the oem upper mount because the new coilovers comes with them! All you need to do is swap the shock bodies and your set! just make sure everything is tight and torqued to spec when finished.
Old 04-16-10 | 08:32 AM
imports4me's Avatar
imports4me
hey guys, forgot to ask.....do you have to take out the rear seats etc to get to the shocks?
Old 04-16-10 | 10:42 AM
Pnuge88's Avatar
Pnuge88
I did mine in fourty five minutes. But then again I had access to airtools and lift at work. All you need is a 10, 12, 14, 17, and 19mm socket. Pry bar. If I did it on jacks one at a time it would take me a little longer. Its not hard.
My settings are 15 all around. I was on the stiffest setting but damn was it hard. Handling was superbb. I like em better then megans when i use to have them.
Old 04-16-10 | 10:53 AM
imports4me's Avatar
imports4me
ok thanks.....did you have to take out the rear interior?
Old 04-16-10 | 11:42 AM
lobuxracer's Avatar
lobuxracer
Tech Info Resource
Pry bar? You didn't reset the bushings to neutral? I feel sorry for your car.
Old 04-16-10 | 12:36 PM
Pnuge88's Avatar
Pnuge88
Taking out your whole trunk interior is unnecessary. Just pull em back.
And lobux what do mean set the bushings back to neutral? The pry bar was just to pull the lower control arm down. Which isnt really necessary cause man strengths enough to get the stock strut out. I did forget to mention i used a spin jack to push the lower control arm back up so i can reattach the sway bar link and the 19mm bolt for the strut/coilover
