What's the minimum front RCA size to clear LS400 calipers?
The Maker
Looks like a one two punch to me. It takes care of the balljoint snapping off (assuming it's better) and act as an RCA.
I'm just scared that it's too thin... our GS is pretty heavy. Plus, can you make the surface area a little bigger (the two circular extrusion)... I don't know, it's just my insecurity.
although, the look about the same size in this pic.
Also, these have been tested with Rcomp tires...so the amount of Gforces imposed are much higher than I am guessing you will see in your GS?
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
jvsc300
Suspension and Brakes
01-29-09 07:34 PM
