What's the minimum front RCA size to clear LS400 calipers?
Master Thread Closer!!
Im running the SAGE front RCA now....its 30mm tall.
Anyone run anything smaller than 30mm and still clear the caliper from rubbing that steering knuckle?
Btw...shaving or grinding down is NOT an option for me.
Thanks.
Pete
Thanks.
Pete
The Maker
looks like I should make one of these for you guys next. This is a full solution for the steering and added brake clearance. With and with out spacer. I still think it is a poor way to deal with this problem to add a spacer, especially with no shear protection. These come with the same alignment inserts designed in the stock parts, machined from mould tool steel.
lowering version 3/4" drop.
Fig
Fig
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
The Maker
top view showing hardened bearing steel bushings that align and provide further shear protection...you cannot trust bolt torque to hold your LBJ against lateral forces.
I need to adapt this to the GS and find a new ball joint...but this has been wrung out pretty good on the race track.
__________________
Looks like a one two punch to me. It takes care of the balljoint snapping off (assuming it's better) and act as an RCA.
I'm just scared that it's too thin... our GS is pretty heavy. Plus, can you make the surface area a little bigger (the two circular extrusion)... I don't know, it's just my insecurity.
although, the look about the same size in this pic.
