Cant seem to get my pedal firm
Im stumped here guys. A few days a go I changed my front calipers, brake hoses, rotors and pads. When I was done I bled the system from back to front, I did it 4x to each brake and my pedal still feels really soft. I made sure there was always fluid in the cylinder so it never went dry.
Do I need to drain the system and bleed it from the Master Cylinder or something else?
Hmm...maybe there's air that's trapped in your ABS valves that you can't bleed out. Some people have success with driving the car (in a safe, remote area) and stomping the brakes to invoke the ABS system and push the trapped air out into the regular lines. Then, go back and re-bleed at the calipers again to get that freed air out.
Hmm...maybe there's air that's trapped in your ABS valves that you can't bleed out. Some people have success with driving the car (in a safe, remote area) and stomping the brakes to invoke the ABS system and push the trapped air out. Then, re-bleed at the calipers again to get that freed air out.
As far as a cylinder, I guess that would depend on how much air you're talking about, and over what period of time, but I can't see any possible way that air would damage a hose
I think the issue of damage relates to a lack of lubrication from the fluid, but you'd have to have a ridiculous amount of air in the system to "dry" out a cylinder. A tiny amount of air can degrade your pedal feel enormously; my guess is that if you had enough air to do damage, basically your brakes wouldn't be working AT ALL.
It took me a few hrs a baseball bat and a big bottle of synthetic fluid to sort it out, the pedal felt 90% better but still feels a little squishy il bleed it soon again but there was ALOT of air in it.
This may sound crazy, but when you replaced the front calipers, did you mount them upside down, where the bleeder screws are on the top and NOT the bottom?
Believe it or not they can be mounted this way! You have to swap them around or change sides. So double check the calipers. Just a thought
You know Im not really sure lol..............I'm thinking it maybe on the top, but I dont know how thats even possible because I changed them one at a time and the right caliper I had to order from rockauto because AAP didnt have it. HMMMMM I really cant remember
EDIT: Ok I just checked and the bleeders on the top of the caliper not the bottom
After some searching, the bleeders are definitely supposed to be on top:
Originally Posted by Supraforums Admin
make sure you installed all calipers with bleeder screws facing up. I had one of my fellow workers install the calipers on the wrong side and they were bleeding it for like 30mins, walked over and yep front calipers were crossed. You will never get all the air out of the system. Also like Rich B said, if the master cyl ran dry you will need to bleed master then the lines.
Maybe I had a brain fart, but I could have swore that the bleeders need to be on the bottom. I wish I was bable to go look real quick to see. Now I am stuck wondering. Can anyone confirm?
yes the bleeders are supposed to be on top, if they are not the system will not allow the air to be removed because there will be an air pocket.
I'm going to pickup a bleeding kit tomorrow and see how that works
