Rotor Replacement
Old 05-02-10, 06:13 PM
kevintq
kevintq's Avatar
you should contact 88rotors..
i purchased their rotor and it has been good to me so far. the guys name is travis or kenn. 110 shipped for drilled slots.. or you can just get blanks and i am sure it is cheaper. what i heard from reading around about 88rotors, they use brembo oem blanks and drill or slot it themselves and its professionally done.
Old 05-02-10, 07:07 PM
acefalcon2
acefalcon2's Avatar
changing rotor is very simple especially on a IS350 Fronts.. the rears are a little trickier..
Old 05-03-10, 07:47 AM
AZ JB
AZ JB's Avatar
I'll look into that, thanks.
Have you seen any DIY? I have only found the DIY with pics for pads, not rotors.
Old 05-03-10, 08:28 AM
acefalcon2
acefalcon2's Avatar
take the calipers out... pull the rotors out....
you'll need 17mm sockets... and either a power tool... or bare strength
Old 05-03-10, 11:26 AM
cdeeznuts
cdeeznuts's Avatar
or like i said earlier an 8mm x 1.25 bolt to loosen the rotor... it goes in the thread on the rotor which pops it loose, which is a lot easier and safer than using bare strength or a rubber hammer.
Old 05-03-10, 04:24 PM
acefalcon2
acefalcon2's Avatar
17mm sockets are to take out the calipers.... no the rotor... rotor pops off the nuts easily once the rotors are out
Old 05-31-10, 03:02 PM
allst4r
allst4r's Avatar
ok this is a dumb question but how do i measure the rotors?
Old 05-31-10, 06:40 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,969 Likes on 2,403 Posts
With a 25mm to 50mm micrometer.
Old 05-31-10, 10:32 PM
RocketGuy3
RocketGuy3's Avatar
I have a similarly stupid question: how can I check the wear on my pads? Will it be possible to do with the car sitting normally in the driveway?
I swear, I feel like such a leech. I think I only come back to the forum these days when I need help with something. I should change that.
Old 06-01-10, 06:45 AM
acefalcon2
acefalcon2's Avatar
if you can see the pads.... without taking the wheels off which is sorta unlikely... yeah you can gauge whether you'll need a new pad...
Andre
YWW
03-18-15 02:13 PM
mansito
GX - 1st Gen (2003-2009)
14
04-15-11 08:13 AM
peehole813
Suspension and Brakes
10-10-10 02:02 PM
Evel
02-23-10 01:03 PM
supaIS350
28
04-06-08 10:42 AM
Quick Reply: Rotor Replacement
