TT Calipers, bled, dead space? Master cylinder upgrade? Anyone?
Originally Posted by RyanV
I would say that if you installed used TT brake calipers you probably need to rebuild the calipers and need to make sure you have new shim/hardware kit installed as that alone makes a HUGE difference alone.
https://www.clublexus.com/forums/sus...r-upgrade.html
Install new shims and you'll notice a smoother feel.
If you've bled the calipers really good and you still have deadspace. Try bleeding the brake master. The proper procedure is really easy to do, but you need two people. I've posted the steps on this forum before and it's also in the Supra MKIV repair manual.
If you rebuild the brake calipers the new OEM rebuild kits are super cheap and come with the special liquid soap you need to lube the seals with.
![](http://img.villagephotos.com/p/2003-5/202062/2jzgebrakeinfo.jpg)
**sigh**
.....OK, so here's further evidence of the confusion/misinformation surrounding this topic . . .
...And here's excerpts from that ^^^ thread link:
And then now we have this:
But, in this table of info, it CLEARLY states that '96 and 97's are ALL 1" or greater in diameter !!
WTF?
I posted a link earlier in the thread. Master cylinders from a 96'+ Supra TT is 11/16th bore, up to 95' Supra TT are the ones to get with the 1" bore.
I was doing some quick research before settling on my brake swap. I have a 98' SC3, so it's a two bolt flange.
Noticed all Supras are two bolt flanges. However, it seems Supras up to 95' have the 1" bore while 96' - 98' has the 11/16" bore. So getting one from a 96' - 98' would practically make no difference. Again it was a quick search, not entirely sure if they are correct.
Can anyone confirm this?
Thanks!
Thanks!
Confirmed by Champion / Jay Marks Toyota, 93' - 95' TT has the larger bore while 96' - 98' has the smaller one.
Any of you 95' - 00' (2-bolt flange) guys should be able to use this master cylinder upgrade with little or no modifications as far as I'm aware. Someone please correct me if I'm wrong.
Should work with 92' - 94' guys as long as you swap over the booster as well.
I plan on doing this down the road; I'll post up any information or mods required when I do.
WTF?
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Man this has me wondering now as well. I searched the major autoparts stores and found listings stating the 96'+ has the smaller diameter; I didn't think this was true, why would they decrease the size?
So that led me to ask the dealer, they confirmed that it was correct. Now this service manual states differently. I better start calling more dealers and find out what's going on.
I have read online that the 26.9mm bore existed, but located in Australia, wasn't sure if they carried over to the states.
I am quite honestly lost again in the search for a proper master cylinder, haha.
Here are some facts.
1. 95 N/A Supra has the 1" brake master
2. 97+ Supra has the 1 1/16th or 1.05" brake master cylinder - I got one of my Supra TT 1.05" masters from ScotturNot
3. After having a 1/16th or 1.05" brake master working the N/A Supra brake calipers on my SC300 for awhile now I can say for certain that the 1.05" master is a definite upgrade for N/A brakes
4. I have the stock 1995 N/A 1" brake master still on my Supra, but I upgraded to TT calipers at all four corners. The car stops decently as it sits...more than well enough for daily/spirited driving.
I will upgrade to the 1/16th brake master and report back with any difference that occurs from installing the larger brake master. I'd expect more initial bite, but we'll see.
These are two quotes from Elmhurst Toyota
1993 NA Supra 47201-14760 Brake Master
1994 TT Supra 31410-14310 CYLINDER MASTER
I just sent a message to the Supra parts guru Curt at Elmhurst Toyota. I'll let you know what he says.
thanks
Curt @Elmhurst confirmed the larger 97+ master cylinder.
47201-14880 CYLINDER BRAKE MASTER LIST 97-8
This is the Supra TT 97-98 upgraded brake master. It has 1.05" where earlier ones have a 1" on the housing.
Long as you have a 95+ 2 bolt brake booster this should be an upgrade according to the Toyota documentation.
__________________
__________________
So let me get this straight, in order to do the supra tt brake swap i need
1.supra tt calipers
2.supra tt rotors
3.supra tt pads
4.supra tt (97+) brake master cyl.
Would that be all?? Thanks everyone for the help.
1.supra tt calipers
2.supra tt rotors
3.supra tt pads
I have a 95 so th 97+ brake master will work right?? Thanks for the help
