Need help please... Front strut won't come out
Old 05-27-11 | 06:27 PM
BLexodus's Avatar
BLexodus
Originally Posted by is150
the F-sport pdf doesnt help either. I had the same problem as you did when i installed my springs. after trying to pry it out for a half hour and reading/re reading the f-sport install guide many times, i realized i needed to have both the front passanger and driver side on jackstands to take the tension off the swaybar, shock then came right out. this way you will not have to remove the swaybar bolt.
Thanks!!!
I just spent 15 minutes trying to pry it off, then I came inside, did a search and found this. After I jacked up the other side, the strut assembly came out rather easily.
I know this thread is getting old but its a good one!
midwest2
17
09-30-11 03:16 PM
kenny_evo
03-27-10 10:01 PM
onlylexus8
Suspension and Brakes
02-27-06 03:01 PM
Shinchan
08-23-01 04:31 PM
