Wheel wobble and steering shaking after installing hubcentric 15mm bolt on spacers!!
Old 07-11-10, 06:22 PM
  #31
Sonic_RC
Sonic_RC's Avatar
CK6Speed makes a very good point. If your car is up in the air bolt the wheel on with the spacer and free spin it. If it moves up and down it may be possible that they drilled the holes off center shifting everything over.
Old 07-12-10, 06:24 PM
  #32
4play4dr
4play4dr's Avatar
hmm....something to look in to..worst case scenario is i will have to end up gettin new ones :/.. the wheels only wobble with the spacers.. anyway to check a bad spacer?
Old 07-26-10, 10:19 AM
  #33
Rezaxxed
Rezaxxed's Avatar
Try replacing them with H&R spacers and go from there. When in doubt, just replace the whole spacers up front with a high quality one. Or borrow some spacers from another GS owner who has a similar setup. I think ICHIBA or H&R are good brands.
Old 07-27-10, 07:22 PM
  #34
4play4dr
4play4dr's Avatar
^^yea..thanks..i have ichiba's in the rear and have no problems..im looking into ichiba v2's if anything
Old 08-01-10, 06:02 PM
  #35
CK6Speed
CK6Speed's Avatar
If you have good ichiba spacers in the rear with no vibration, swap the offending front ones in the rear and see if the problem follows. If so, than its the front spacers. If not, than try swapping the good ichiba spacers from the rear onto the front and see what happens.
Old 09-29-10, 11:21 AM
  #36
pizdets17
pizdets17's Avatar
I have ichiba in the back which cause no issues but when I bought them for the front the car drives like ****.
Old 10-01-10, 12:16 AM
  #37
4play4dr
4play4dr's Avatar
really? did u ever figure out why? were u using hub centric rings?
Old 10-01-10, 07:30 AM
  #38
pizdets17
pizdets17's Avatar
yep ichiba v2 60.1. Will do the daizen swap in about two weeks and see if that helps, my guess is they just take the regular vibration I already have and multiply it by x10 lol
Old 10-02-10, 02:46 AM
  #39
4play4dr
4play4dr's Avatar
hmm....maybe upper control arms? i havent even figured my situation out yet
Old 10-11-10, 12:11 PM
  #40
SH_JZZ30
SH_JZZ30's Avatar
Do your wheels have the indentations on the inside of the hub for the studs sticking out? My work wheels don't have that so I have to use extended studs and slip on hubcentric spacers.
Old 10-11-10, 07:14 PM
  #41
4play4dr
4play4dr's Avatar
yea my wheels have space for the studs
Old 10-11-10, 07:45 PM
  #42
5t341th
5t341th's Avatar
damn still havent fixed it. take ur rear ones and put em up front. see if it goes away. or go borrow from somebody
Old 10-11-10, 07:47 PM
  #43
pizdets17
pizdets17's Avatar
my rears are bigger if I put them on the front ill need new fenders lol. Also I just stripped one of the lugnuts, is it me or are those ichiba lugnuts total sh7t?
Old 10-11-10, 08:40 PM
  #44
4play4dr
4play4dr's Avatar
haha i havent fixed mine yet tryna get the body work done first..probably jus gonna get new spacers..anyone heard of POWERED by MAX spacers?
Old 10-11-10, 08:49 PM
  #45
5t341th
5t341th's Avatar
yea 240/drift shop.
i dont think they make it in 1.5 thread pitch. i remember looking. it looks tight cuz its all orange.
poweredbymax.net
Quick Reply: Wheel wobble and steering shaking after installing hubcentric 15mm bolt on spacers!!
