Wheel wobble and steering shaking after installing hubcentric 15mm bolt on spacers!!
Old 10-11-10, 09:42 PM
  #46
4play4dr
4play4dr's Avatar
my friend was tellin me he had em on his SC with no issues..but its like 150 for the adjustable spacers..i only want 15mm
Old 10-12-10, 01:30 PM
  #47
GS300ToM
GS300ToM's Avatar
shieeet i just took off my spacer and driving with my stocks.. no more vibrations, i was using 15mm ichiba V2 spaers front and rear.. shook really bad but i got used to it haha.. sold my wheels and on with the new with no spacer at least for the fronts haha but im looking to put a 10mm on the back
Old 10-12-10, 03:16 PM
  #48
pizdets17
pizdets17's Avatar
i hate this damn vibrating car..
Old 10-13-10, 11:42 PM
  #49
4play4dr
4play4dr's Avatar
i still dont kno what the problem is..i havent had the spacers on for a while..debating on buying new ones..ichiba's probably..at least they have a reputation..hopefully its nothing else and that its was jus a faulty spacer set
Old 10-14-10, 09:36 AM
  #50
pizdets17
pizdets17's Avatar
put my oem 16's on and guess what? Drives like a dream...Tried 3 diff sets of 18's and vibrates like *****, oems- rides like a caddy. WTF now?
Old 10-15-10, 12:29 AM
  #51
5t341th
5t341th's Avatar
cuz of the big sidewall. plus small wheels balance themselves easier.
i got my wheels fixed so they are straight. i got 15mm ichiba v1 spacers and hubcentric rings.
my car drives perfect now.
Old 10-15-10, 05:03 AM
  #52
SH_JZZ30
SH_JZZ30's Avatar
Are you running the oem wheels with the spacers? When you run the aftermarket wheels, you should use the hub centric rings. Even if you have hubcentric spacers, they aren't hubcentric to aftermarket wheels. They are meant for oem Lexus/Toyota hubs. Also what lug nuts are you using?
Old 10-15-10, 06:23 AM
  #53
TheRonTom3
TheRonTom3's Avatar
Make sure that your spacers to hub bolts didn't loosen up also. I know with the spacers I was running there was a 40% chance after the first 50 miles a bolt or two would loosen a bit so I always went back and retourqued after 50 or so miles.
The problem with a good majority of ebay spacers is it may be hub centric but then the outside of the bore has no lip to sit a hub centric ring on for the wheel which kind of negates the entire purpose of being hub centric
Old 10-15-10, 10:29 AM
  #54
pizdets17
pizdets17's Avatar
Yes running my 16's with spacers, also you guys must have missed the fact that my 18's are also hubcentric as they are 3GS rims. Circumference is almost the same (25.7" on 16's and 25.5" on 18's) all lugs torqued to 76lb. I am not a noob that just did this yesterday. ANY rims bigge than 16" seem to vibrate the **** out of the car with spacers or without for some reason. Nobody can figure it out. Also new ball joints, tie rods, studs, spaces, wheel balance, rf balance and so on..
Old 10-15-10, 10:44 AM
  #55
sakataj
sakataj's Avatar
says the guy who just punched a hole through the bottom of his car and into his car with a jack....
jk had to mess with ya on that
Old 10-15-10, 10:51 AM
  #56
pizdets17
pizdets17's Avatar
thanks, guess it was my fault a $300 jack blew up..But hey you're on your way to 10,000 posts Brian so that's something! Not funny.
Old 10-15-10, 11:52 AM
  #57
sakataj
sakataj's Avatar
if we weren't in the transition between heating/ac seasons i wouldn't be so bored lately (aka so active)
lol
i was just messing with you....i use the forklift at work as my jack
Old 10-15-10, 11:55 AM
  #58
pizdets17
pizdets17's Avatar
This has been an expensive week. With no boxes to show for it...
lol
rgonza1
04-04-15 08:34 PM
JamesG
07-08-13 04:04 PM
LilMan23
02-09-11 02:28 PM
designo
11-08-10 11:53 AM
telmz1
12-29-09 03:17 PM
Quick Reply: Wheel wobble and steering shaking after installing hubcentric 15mm bolt on spacers!!
