Master Cylinder Upgrade
I was doing some quick research before settling on my brake swap. I have a 98' SC3, so it's a two bolt flange.
Noticed all Supras are two bolt flanges. However, it seems Supras up to 95' have the 1" bore while 96' - 98' has the 11/16" bore. So getting one from a 96' - 98' would practically make no difference. Again it was a quick search, not entirely sure if they are correct.
Can anyone confirm this?
Thanks!
Thanks!
Confirmed by Champion / Jay Marks Toyota, 93' - 95' TT has the larger bore while 96' - 98' has the smaller one.
Any of you 95' - 00' (2-bolt flange) guys should be able to use this master cylinder upgrade with little or no modifications as far as I'm aware. Someone please correct me if I'm wrong.
Should work with 92' - 94' guys as long as you swap over the booster as well.
I plan on doing this down the road; I'll post up any information or mods required when I do.
I am currently running the TT master cylinder. I got it new from carson toyota. Did the upgrade while I did the LS swap so I cant tell you for sure how much of a difference it made by itself, but the car does stop on a dime I will tell you that much..
juanikun
SC400 / 300 Classifieds
04-15-16 09:45 AM
