ball joint bushings rebuildable?
Old 05-24-10, 04:12 PM
rwdanthony
rwdanthony's Avatar
Default ball joint bushings rebuildable?
are the ball joint bushings rebuildable?
issue: ball joint moves freely but isnt tight, it feels loose [some play]
i know the rubber covers/dust boots that hold the grease are replaceable with energy suspension dust boots?
but i would like to know if replacing the grease would help any, and if theres anything else that we can do about it.
Old 05-24-10, 04:41 PM
Blkexcoupe
Blkexcoupe's Avatar
The ball joints themselves aren't rebuild-able or replaceable on our cars, so buying a complete control arm is the only option for replacement.
Adding more grease might help, but in reality if you know there is some play in the joints you should consider saving up or expect to have to buy new arms in the future. If it is the front LCA/balljoints, then you can use the supra LCA as replacements. If you need the front UCA/balljoint or rear then you will have to take a trip to Lexus.
Old 05-24-10, 04:47 PM
rwdanthony
rwdanthony's Avatar
upper control arms are fine, im getting myself an extra set of LCA w/ daizen polyurethane bushings already, but the ball joints has the condition i stated above.
i already knew the ball joints weren't replaceable, but only the entire control arm itself, that has the ball joints built in.
i may just end up opening, cleaning, greasing, and get new dust boots from energy and see what happens.
Old 05-31-10, 02:32 AM
DA51
DA51's Avatar
Default ball joints
Ball joints have a test to see if they are good or bad. The Shop manual says to wiggle the joint back and forth, then, turn the stem 4 times, the 5th time use a torque wrench and measure the resistance. It should be 9-30 in. lb.
I'm replacing all the 18 year old parts with 155,000 miles.
the LCA ball joints and back bushings were shot, but the UCA ball joints were good and the Tie Rods ends were good, too.
I used a Pickle Fork to remove the joints which ruined the boots.
Anyway, the new parts should last my lifetime.
Attached Thumbnails ball joint bushings rebuildable?-img_0009_320x240.jpg   ball joint bushings rebuildable?-img_9996_320x240.jpg   ball joint bushings rebuildable?-img_9998_320x240.jpg
Old 06-10-10, 04:31 PM
jdm93400
jdm93400's Avatar
wow that is shot so wat did u end up doing gettin new ones or wat
Old 06-10-10, 07:02 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
IM still wondering why these are made where you have to replace the whole control arm. I know the LS400 you can just replace the outer ball joint. WTF?
Old 06-10-10, 07:42 PM
rwdanthony
rwdanthony's Avatar
i got a different set of used LCA all together, and put in my delrin bushings into them.
https://www.clublexus.com/forums/sus...verhaul-3.html
the LS has a different suspension design, simple as that.
Nguyen07
Suspension and Brakes
02-13-14 08:06 PM
SCSpeed
11-19-07 10:08 PM
JohnGS4
05-23-06 01:20 PM
persian451
07-13-03 12:28 AM
Nick T
14
06-30-03 11:44 AM
Quick Reply: ball joint bushings rebuildable?
