installation tomorrow
Old 06-13-10, 07:34 PM
vinhtrandi
vinhtrandi's Avatar
Default installation tomorrow
i will be installing this in tomorrow because my left tie rod is bent..... will take pictures more pictures tomorrow....
[IMG][/IMG]
vinhtrandi is offline
Old 06-13-10, 08:19 PM
5t341th
5t341th's Avatar
ur tie rod is bent? so u are installing those rear toe links?
5t341th is offline
Old 06-13-10, 11:37 PM
vinhtrandi
vinhtrandi's Avatar
i meant rear toe rod.
Old 06-14-10, 12:15 AM
5t341th
5t341th's Avatar
coool how much do those run? i am needing some toe correction
5t341th is offline
Old 06-14-10, 12:50 AM
YviE
YviE's Avatar
They look sweet !!
YviE is offline
Old 06-14-10, 02:32 AM
PHML
Master Thread Closer!!
PHML's Avatar
nice...post pics of the install...as well as the toe numbers (before and after).
PHML is offline
Old 06-14-10, 03:45 AM
vinhtrandi
vinhtrandi's Avatar
what you mean by the toe numbers???? im still learning a lot... So far I have learned alot from this CL about my baby "ARISTO"
Old 06-14-10, 03:52 AM
vinhtrandi
vinhtrandi's Avatar
rear toe arm $160
rear toe rod $120
this company makes it
http://www.hardrace.com
I purchased it through this company
www.topspeedauto.com
Old 06-14-10, 03:56 AM
Mr Jokster
Mr Jokster's Avatar
well, after you change these parts, you gotta get an alignment. so hes asking for you to get the car put on the machine for before 'numbers' of how your toe is, then compare to what you get after you put it on...
( on that note, never understood before and after requests since its just a replacement and not a correction)
Mr Jokster is offline
Old 06-14-10, 07:00 AM
excluesive
excluesive's Avatar
I installed these and got great adjustment from the two pieces on the bottom. Can anyone explain what the purpose of the TRACTION RODS? We tried adjusting them, but didn't see any affect on the machine.
excluesive is offline
baconcake
Suspension and Brakes
05-19-15 01:47 PM
nandob
02-21-14 05:29 PM
Quick VR-4
03-03-10 01:48 AM
Quick Reply: installation tomorrow
