Camber kits?
I just take mine to the dealer and tell them I want the toe settings to be neutral, regardless of the effects on the camber.
They excuse they always give for lowered cars is that they are trying to get your camber back in spec to "prevent" tire wear and there are no specific camber adjustment, so they have to comprise with some toe adjustments.
Tech Info Resource
I have the same issue, I'm running pure stock, and my right front tire did look very similar.
I went to lexus dealer to check on my camber, and they said that everything is perfect (I'll post measurements in next post once I find the data sheets)
The alignment is perfect, (I checked it in lexus dealer) I'm thinking that my damper is dead, so when I drive the wheel is jumping too much and it is ripping off the tire.
mikemareen
05-20-08 11:20 AM
