4 lowered SC's/After market inner tie rods issue
Has any of you lowered SC's had worse negative alignment issues with aftermarket inner tie rods?Like Autozone,NAPA,Advanced Auto etc.?I had a bent inner tie rod on the driver side and after installing Advanced auto ones my alignment on my drivers side is maxed out at -1.50 when it was -0.3 before.Passenger side is fine at -0.4.Would it be possible to cut off a few threads on the inner tie rod or does that only control the toe?Any ides,experiences like this?
check other things in the suspension carefully. if you can get your toe to correct spec then there is an issue somewhere else.
btw why are you running so little camber anyways? i run -2.0* all around and it is a night and day difference from stock. the car handles so much better.
JeffTsai
08-18-16 08:33 PM
excluesive
Suspension and Brakes
03-31-10 06:47 AM
