Lowered problem/Alignment issues...
so last saturday i installed the BC racing coilovers and lowered the car. I didn't even lower it that much in my opinion, especially not compared to a lot of cars on the forum. i brought it to a nice shop which had the hunter alignment machine and they basically gave me a call later in the day stating that wouldnt be able to align it properly because of the negative camber in the back and that it would be a waste and that i would still need tires yada yada yada. So I called firestone and the dude said as long as they could get it on the rack they would be able to do it, i went this morning drove all the way there and they basically said the same thing.
you dudes who are lowered, what do the shops who align your vehicles have to say about the neg camber in the rear? and also do alot of you guys run camber correction kits or anything? why wont any one align my car? is this something that you lowered guys just live with? any input would be much appreciated![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
ps im on stock wheels
What is it that they don't kno how to do? Aren't they an alignement shop for a reason? I'm sure I could get on the lift. Do they not realize there is a camber adjustment in the rear or what?
Ur alignment guys are idiots. Negative camber plays a very small role in tire wear. The biggest issue is toe and caster. Go to the alignment shop and tell them to put the camber as far positive as can go and put toe and caster as close to spec as possible. The camber will be -2 or less depending on how much u r dropped and toe and caster should be within spec. I drive pretty low and my caster and toe is pretty much within spec front camber is -3.2 and rear -3.6. Find a good shop or come to NYC.
UPSTATELEX, how far upstate are you? Maybe you can try the shop that LudeNSol finally found to get his taken care of.
Dudes, this is the most unbelievable thing I ever went through with my car. I appreciate all your input. I'm in Syracuse ny. Will be in city for fourth of July weekend. Just didn't plan on bringing my car. Any more info would be great. ESP if upstategs knows anyone in Rochester that'd be closer.
This statement is incorrect.
First off, lets start with what were the readings? While some negative camber is not always harmful and is actually required in some applications that blanket statement does not cover a range. If you are 2-3* out of spec, you can bet you are going to have pre-mature and un-even tire wear.
Second, you are correct about toe, having you car out of toe spec can literally translate ( over a year) of you dragging your tire sideways on the ground for miles.
Third, Caster is an alignment/ steering angle. It is the forward or backward tilt of the upper ball joint or top of the strut relative to the lower ball joint. This will ONLY affect steering ability and how your wheel returns. Improper caster does not have a direct affect on tire wear.
As for the OP, post your specs and I ( or other members) can help you out.
Thanks!
Travis
Specialty Products / SPC Performance
Good luck
Yes, that's exactly what I'm talking about sam. And Travis, they wouldn't even align it so as of right now I don't really have any specs. Both shops wouldn't touch it, I'm not even slammed. Barely tucking tire at all.
