Help: Brake noise wont go away!
Old 06-27-10, 03:34 PM
truenoboy
truenoboy's Avatar
Default Help: Brake noise wont go away!
I notice noise coming from the front passenger brakes when I apply the brake pedal. Twice now I've taken it apart and applied brake grease to the shims and pads, which eliminates the noise temporarily, but after a few weeks, the noise each time comes back. I can also hear slight rattling from the same caliper when I hit bumps in the road. I have a feeling it may be loose shims, but I don't know how to resolve this. It's driving me crazy.
Anybody ever have this issue or have any suggestions to help me resolve this.
Old 06-27-10, 04:05 PM
SC4NLV
SC4NLV's Avatar
have you replaced your pads? if so did you have the rotors turned? maybe you ride the brakes a lot?
Old 06-27-10, 04:13 PM
knguyen
knguyen's Avatar
sounds like you need new brake pads
Old 06-27-10, 06:34 PM
truenoboy
truenoboy's Avatar
No, I don't need new pads. The pads and rotors are fairly new. I've been having this noise with the old pads and rotors, causing me to think that I need to change my brakes, so I changed everything, and the noise is still there.
Old 06-28-10, 01:03 AM
YviE
YviE's Avatar
Maybe the sliders pins are frozen and don't release the caliper quick enough?
As for the rattle, is the caliper securily bolted to the bracket?
Old 06-28-10, 03:05 AM
Mr Jokster
Mr Jokster's Avatar
I checked my brakes a couple years ago ( about a year after I bought the car) thinking I too needed pads, when I went to pull them off, They were silicone on by previous owner... Maybe they had the noise too
Old 06-28-10, 03:47 AM
magz
magz's Avatar
If I understand correct what the sliders pins are, check whether they are on their place as the upper one differs from lower
Old 07-02-10, 07:07 PM
truenoboy
truenoboy's Avatar
I need to figure out what slider pins are, cause I have no clue. What I thought was a slider pin is not apart of the brake assebly, so my assumption of slider pins must be wrong.
Old 07-03-10, 01:53 AM
Mr Jokster
Mr Jokster's Avatar
Old 07-03-10, 01:54 AM
magz
magz's Avatar
As you see on a scheme one is MAIN other is SUB. Seem when you were changing the pads the pins were mixed.
We had the same problem here
Attached Thumbnails Help: Brake noise wont go away!-pins.jpg
Old 07-03-10, 02:38 AM
xfea
xfea's Avatar
Now I'm confused.
I am about to do my front brakes - never took them apart ( '01 GS 300 )
but this shows main and sub pins with the same part number.
What gives?
And -- which is the best DIY for '01 GS 300 front brakes?
The DIY's I looked at were for different models - not for '01 GS 300 specific.
Thanks
Old 07-03-10, 02:57 AM
Mr Jokster
Mr Jokster's Avatar
Originally Posted by xfea
Now I'm confused.
What gives?
Thanks
I thought the same thing too, but when you go to sewells site, they have different sub-part numbers and are also priced different:
Attached Thumbnails Help: Brake noise wont go away!-parts.jpg
Old 07-03-10, 02:58 AM
Mr Jokster
Mr Jokster's Avatar
wow, quality really goes to craps with attachment huh
Old 07-03-10, 10:50 AM
xfea
xfea's Avatar
Thanks - now which is THE DEFINITIVE DIY for front brake pad replacement for a '01 GS 300?
http://www.lexls.com/tutorials/brake/fbpad.html
This is a clear DIY but it's for an 90-94 LS 400....
Old 07-03-10, 10:57 AM
sam430
sam430's Avatar
me too... brand new rotors and pads and it's squealing. Good thing it's an LS brake, so I can easily take it off and put some anti squeel... it didn't come with the brakes when I bought it.
brembo blanks+FERODO.
upgraded rotors were not cost effective.
Quick Reply: Help: Brake noise wont go away!
