1992 SC300 Rotor fitment
I am trying to put some new rotors on my SC300 and the fronts just slipped on but the rears seem to be the wrong kind, as you can see from the pictures the oem has an outter lip and also an inter lip (maybe you can see it maybe you cant) but the bearing sit on that inner lip, i cant see how it would work without it.........am i missing something?
![](http://i72.photobucket.com/albums/i190/THEGROUNDSTREETBALL/IMAG0065.jpg)
Use a 8mm x1.25 (I believe) bolt in the two little holes that are thread tapped (see new rotors) Thread them into the same holes on the old rotors on the car, tighten and you will be golden (bolts push off the rotor). Make sure the parking brake is off. The middle part that has the lip that sticke out from the rotor usually rusts and sticks a bit (PB blaster or WD-40 helps). I hope that helps.
Yep.You're assuming that's all one piece. The rust around the lip is what's confusing you. Do what this guy says:
GS300 I6
09-08-09 06:29 PM
