You can peak into the calipers to see the pad material, if it looks like about 3mm or less, then it is time to change...but keep in mind that the fronts will always wear faster than the backs...
The answer is right above you Look at the rear pads to see if they need to be changed. If they are low on pad life, then replace. If not, then just replace the fronts.
