Clanking or rattling
Old 06-29-12, 07:51 AM
  #31
MonkikiX
MonkikiX's Avatar
I just got my hardware kit to replace the rear but from the pics I see there is only one pin in use per caliper and I've read that there should be two per caliper... Using only one I could see that causing noise as it allows the pad to hinge on one end but maybe two would not allow the pads to move as freely. Can anyone confirm if there should only be one or two pins per side?
Old 06-29-12, 04:55 PM
  #32
ChampGS3
ChampGS3's Avatar
Nope the rear calipers have only 1 slider pin. That hardware kit will not dissapoint you when getting rid of the dreaded clanking.
Old 06-29-12, 05:16 PM
  #33
MonkikiX
MonkikiX's Avatar
Okay. Thanks. Can't wait to finally be rid of the clanking!
Old 06-30-12, 11:44 PM
  #34
MonkikiX
MonkikiX's Avatar
And the noise is gone! Mine didn't have the springs at all and it took all of about 10-15 minutes from start to finish too.
Old 07-21-12, 01:48 PM
  #35
hobojoe
hobojoe's Avatar
Originally Posted by 394LEXUS
the V shaped spreader srings on the rear pads were non-existent on my 00 gs300. replaced the pads and used all new hardware and problem is now gone. it was pretty irritatiing
I have the same issue on my 98 300 that I just bought. Would you be able to take a picture for me of how the silver V spreader springs fit into place with everything else? I haven't been able to figure it out from the diagrams and they don't have holes to slide into like on my LS I had.
Old 07-21-12, 02:16 PM
  #36
MonkikiX
MonkikiX's Avatar
If the rears, the 'W' faces towards the back of he car. Clip the bottom of the 'W' into the rear holes of the brake pads then the top of the 'W' into the forward holes of the pads...if that makes sense. Then the metal plate on top with your pins.
Old 07-15-15, 09:42 PM
  #37
slimstady
slimstady's Avatar
Default Low speed clanking noise.
Check for something loose inside the tire like the TPM. happened to me after a tire change. Had a low speed clanking noise. Jack the car up and spin the wheels.
gs350lex
01-27-19 10:00 AM
BostonVP
04-23-11 09:00 PM
brazil954
Performance & Maintenance
07-31-09 09:08 AM
SGMIS3
07-16-08 01:08 AM
messysc
SC- 1st Gen (1992-2000)
10-18-02 12:34 PM
Quick Reply: Clanking or rattling
