Toms advox coilover help
Old 09-27-10, 11:18 PM
Newchapter
Newchapter's Avatar
I was looking for gas not spring rate but my email was titled GS400 rebuild and I was told 7kg as well. This equates to just under 100psi and is what I'm going with tomorrow.
Old 10-09-10, 05:57 PM
aEO 37
aEO 37's Avatar
So Advoxx are filled with nitrogen only. No oil?
Old 10-10-10, 07:07 AM
LEXXIUM
LEXXIUM's Avatar
Yes, there is oil inside of the shock, but the bottom of the shock has a valve for nitrogen to adjust the the pressure for firmness or softess. So it uses both in different chambers.
Old 02-08-11, 06:44 PM
entryspeed
entryspeed's Avatar
well I dont know what kg to air pressure is but in terms of weight and not to revive and old thread this is just fyi for any one researching 9kg = 19.8lbs in weight conversion factor.
Old 02-08-11, 07:14 PM
GSteg
GSteg's Avatar
There is no such thing as a conversion from spring rate to pressure in nitrogen. They filled the pressure of the nitrogen independent of the spring rate.
Old 01-29-13, 08:54 AM
1CleanSC
1CleanSC's Avatar
Would anyone testify that it's worth paying the "pretty penny" for the Tom's Advox coilovers? Cause they're not the cheapest haha.
Old 01-31-13, 09:36 AM
Nguyen07
Nguyen07's Avatar
just had mine refilled with nitrogen to 12lbs..at tire discounters
I replaced all the valves with new ones from "Fox" racing.
Old 11-18-16, 01:22 PM
Dylxkelly
Dylxkelly's Avatar
I have toms advox coilovers for my altezza and they have started banging when driving is this a matter of changing the valves and topping up the gas or is there a bigger problem ?
Thanks
PRESIDENTE
08-08-12 02:59 PM
Big Phil
04-12-10 09:11 AM
Lazy
15
07-11-08 04:37 PM
Tank
Suspension and Brakes
02-15-08 11:04 AM
J0hnP
10-22-06 08:14 AM
Quick Reply: Toms advox coilover help
