rear brake fluid pressure low
I just installed a used brake master cylinder because I thought mine was bad.
I first tried to bleed the brakes with the old unit that was in my car but with the key on there was very little fluid coming out, so i replaced the master cylinder and its slightly better pressure in the rears but its not spraying out like most cars i have bleed, its just kinda of oozing out. The fronts on the other had were shooting out with the key off.
I need some input. I read somewhere that if you disconnect the ABS fuse you can do it manually. Can i just unhook the battery?
Or if not what is the proper procedure also is it the abs fuse by the battery 1 and 2?
